edit - the above link answered my question - it's up and running!. thanks Pilot6 and shadow.
I am a Linux newbie. I am trying to install the Oracle JDK 8 and NetBeans on my computer.
My internet connection is quite slow, so I have previously downloaded the tar.gz file from Oracle. However, being such a newbie, I'm already stuck.
The instructions tell me to locate it in a folder of my choice, then extract and install it by running tar. Is there a preferred location?
I attempted to create a /usr/java folder via the graphical interface, but I seem to require root access, and don't quite know hope that works.
Can anyone help?
You can copy your downloaded file into
/var/cache/oracle-jdk8-installer/
Please make sure you have the correct file, at the moment of writing this would be jdk-8u77-linux-x64.tar.gz
The oracle-java8-installer should then recognize the file and not attempt to download it.
Chris
  • 31
Run in terminal
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java8-installer
This is the easiest way to install it. And you will get automatic updates.
Pilot6
  • 92,041
Run these commands in terminal:
First you have to add oracle's repository where you can download java
And the you must update your local package list
sudo apt-get update
Then you can download the installer
shadoww
  • 16
