I'm using Terminator as my terminal. Is there a built-in way to find/search through the output backlog? I'm not looking for grep and piping a command, or piping into less or vim.
Terminator has a built-in search (ctrl-shift-f is the default keybinding), but it doesn't highlight the found text, which makes it fairly useless.
There's a bug open against terminator to fix this, but right now it's still unresolved:
https://bugs.launchpad.net/ubuntu/+source/terminator/+bug/271487
- 756
- 6
- 4
You can install latest version on ubuntu where the bug is solved
sudo add-apt-repository ppa:mattrose/terminator
sudo apt-get update
sudo apt install terminator
See https://github.com/gnome-terminator/terminator/blob/master/INSTALL.md
- 761
- 2
- 8
- 21
This actually has been resolved for terminator 2.1, yes good things do happen in 2020. However it's not on the repo yet, but you can clone the
github terminator repo
And follow the steps form install guide
Basically it will take you to
git clone git@github.com:gnome-terminator/terminator.git
sudo apt-get install python3-gi python3-gi-cairo python3-psutil python3-configobj \
gir1.2-keybinder-3.0 gir1.2-vte-2.91 gettext intltool dbus-x11
In the folder where you've cloned the repo
python3 setup.py build
python3 setup.py install --single-version-externally-managed --record=install-files.txt
you should be able to spawn a terminal from that point by running from the folder where you've cloned the repo
python3 terminator
And have the desired search working
- 171
