So, the software updater comes up and says that there is a new Ubuntu version, do you want to upgrade it or not. I accidentally press yes. After that I interrupted the upgrade by closing it, and rebooting.
Now I can't download packages, because they're disabled. It says:
Disabled on upgrade to Xenial
How can i stop that upgrade to Xenial?
This is my first question, so I apologize if it's formatted incorrectly. .
Bruni
  • 11,099
Akar
  • 113
I don't know how you managed to get trusty to upgrade to Xenial, which is still not finished. Scheduled to be released on April 21st.
To revert the changes
  • In the Software & Updates go to the tab Other Software
  • enable all the Trusty packages,
    • or rename the xenial part to trusty.
To set it to a default setting do the following:
  • In the dash search for Software & Updates
  • Open Software & Updates
  • select the Updates tab
  • in the Notify me of a new Ubuntu Version, select For long-term support versions
This will only notify you when Xenial, the stable version, is out
Note: None of this is recommended, and might break your system. Use at your own risk.
I'd recommended to do a full backup of everything and just do a clean install.
See the following Q/A for further information on how to rollback to a previous version of Ubuntu:
blade19899
  • 26,994
