I tried to install dropbox and suddenly it couldn't finish installation. I tried from the terminal to do it manually and the same,it stucked at 100%. These are two of the problems are coming through terminal:
E: Could not get lock /var/lib/apt/lists/lock – open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Also when i tried to do software update is coming this problem:
Software index is broken
It is impossible to install or remove any software. Please use the package manager "Synaptic" or run sudo apt-get install -f in a terminal to fix this issue at first.
I tried to fix it but is still the same problem. How can I solve these problems? Thank you
