When I run updatedb from a terminal, I get this error:
updatedb: can not open a temporary file for `/var/lib/mlocate/mlocate.db'
Any ideas about how to get updatedb to work?
xiota
  • 5,038
I realize this is an old post, but I do not see this solution elsewhere.
The problem is not the mlocate.db file, as you'd expect. It is the permissions on the mlocate executable. This will fix the issue:
sudo chmod 2755 /usr/bin/mlocate
This is the source of the trouble:
$ ls -lathr /usr/bin/mlocate
-rwxr-xr-x 1 root mlocate 39K Nov 17  2014 /usr/bin/mlocate
You need a setuid bit on the group to allow you to run the locate command without sudo. Once it is fixed, your ls output should look like this:
-rwxr-sr-x 1 root mlocate 39K Nov 17  2014 /usr/bin/mlocate
Simply doing a chmod as some others recommend against the db file itself will only work until the next time someone runs updatedb. Then the permissions will be reset.
Martin Thornton
  • 5,996
  • 32
  • 43
For me after updates to Ubuntu 14 I still kept getting
$ locate chruby
locate: can not open `/var/lib/mlocate/mlocate.db': Permission denied
so the issue was not about broadening read permissions on that file, unlike other answers say.
My "nonrootuser" is master. So as root I added that user to the group mlocate:
# addgroup master mlocate
After listing the details of that directory to see ownerships:
# ls -al /var/lib/mlocate
drwxr-xr-x  2 root root        4096 Jun 19 13:21 ./
drwxr-xr-x 94 root root        4096 Jan 23 11:27 ../
-rw-r-----  1 root mlocate 50134121 Jun 19 13:21 mlocate.db
Marcos
  • 730
Please run the command with sudo:
sudo updatedb
chili555
  • 61,330
-1
Read man updatedb and learn how to write updatedb's output elsewhere, in a directory you have write permission for.
waltinator
  • 37,856
