49
A bit before upgrading from 10.04 to 11.10, my Ubuntu desktop stopped allowing me to access my Windows share directories. I figured I'd upgrade to 11.10 and the problem would get fixed but no.
Whenever I click on a Windows network domain using Nautilus, the following message pops up.:
Unable to mount location - Failed to retrieve share list from server
Where do I start troubleshooting this problem? I am getting desperate now :(
I tried
sudo mount -t cifs //SomeMachine/SomeShare some_directory
and I get
mount error(115): Operation now in progress
Strangely enough, I got a popup stating:
Could not display network:/// Error: Dbus error org.freedesktop.DBus.Error.NoReply: Did not receive a reply ...
d a i s y
  • 5,551
jldupont
  • 861
15 Answers15
13
I found this advice from Gord Nickerson worked for me: The error message is 'failed to retrieve share list from server' so it cannot browse a Windows 7 pc or a Ubuntu 10 pc or a mac desktop pc.
First of all, the Samba daemons smbd and nmbd must both be running for network browsing to work. They can be started with service, or with systemctl start for the newer systemd-based releases of Ubuntu.
smbtree lists all the shares from machines on the network.
So, off to /etc/samba and we sudo pico smb.conf.
The name resolve order uses hosts files first and broadcasts last and it is commented out! Maybe we change that to:
name resolve order = bcast host
and then restart the servers with service smbd restart and service nmbd restart
Works! This is an awful mistake to make in an upgrade. Upgrade should not break what is working, particularly something as important as networking. Good thing i recall the manual work you had to do to get samba working back in redhat 5 and 6.
Jeff King
  • 139
11
This is the true answer of your question. I also had the same problem.
Run terminal and enter this command
gksudo gedit /etc/hosts
and add computer ip address and name in hosts file. Save and exit.
Sample ip and name:
192.168.120.65    blablaPcName
Thats all.
The problem (at least in Ubuntu 18.04 where I tried it) is that the following command:
sudo ufw allow Samba
will only add rules for Samba acting as a server. It will not add any rules for Samba acting as a client. But when you try to mount a remote share, that's what you are doing: in this scenario your machine is a client, and the remote machine is a server.
Also, the "no reply" error is a hint that some firewall is messing things up. Machines do generally respond to requests. They may respond with an error, in which case you have other problems, but if they don't respond at all, then their packets are usually being eaten up by a firewall.
The rules that allow Samba to act as a server are not sufficient to also allow Samba to act as a client, because the remote machines respond from their own port 137, but the local port on which these responses arrive is not 137, it is some random port.
To solve this problem, execute the following command:
sudo ufw allow in proto udp from any port 137,138 to any
This will allow UDP packets to arrive into any local port as long as they are originating from port 137 or 138 of the remote computer. The port 138 is probably not necessary, as I have only seen packets arriving from 137, but you never know.
This is probably insecure, because the originating port can be spoofed, but let's not be paranoid.
This fixed it for me.
It's possible this is a general error connecting to the system:
In the above thread case, there was a mismatch between name and IP address, and nmblookup helped determine the problem. Also, this page seems to have some good troubleshooting tips
That I'm copying out:
  • Put smbclient into debugging mode, output should show up in dmesg (-d|--debuglevel=level)
  • smbclient -L //<IP of Samba Server> -U <server user>
  • nmblookup {name}
  • Can you mount from other systems?
Edit up your question if you do more troubleshooting.
dpb
  • 7,209
When accessing a windows server on Ubuntu 20.04 with samba version 4.11.6, I solved the issue by adding to /etc/samba/smb.conf the lines below.
#### Networking ####
client min protocol = NT1
server min protocol = NT1
name resolve order = bcast host lmhosts wins
parovelb
  • 121
Just add "allow out" to the firewall:
  • Port 137/UDP - used by nmbd
  • Port 138/UDP - used by nmbd
  • Port 139/TCP - used by smbd
  • Port 445/TCP - used by smbd
And it will work, and if you do not know how to, just install "gufw", and use the "+" and then the "simple tab".
Eric Carvalho
  • 55,453
Joao
With Ubuntu 14.04 :
This error can be caused by a netbios name having a size greater than 15 characters. It should generate logs in the file /var/log/samba/log.smbd looking like this :
register_name: NetBIOS name NAME-OF-PC-TOO-LONG is too long. Truncating to
This error can be fixed by editing the file /etc/samba/smb.conf and adding the following line :
netbios name = NAME-OF-PC
NAME-OF-PC shall not have more than 15 characters.
AizeLauna
  • 121
Try logging into a Windows box from Ubuntu using Files. Go to "Other Locations" and "Connect to Serer" down the bottom. Use smb://username@serveraddress. This worked for me.
I've had very good results in mixed network environments (Windows/Ubuntu) with this method:
  1. Press Alt+F2 and type: gksu gedit /etc/nsswitch.conf
  2. Look for this line:
    hosts:  files mdns4_minimal [NOTFOUND=return] dns mdns4
  3. Add wins so it looks like this:
    hosts:  files mdns4_minimal [NOTFOUND=return] wins dns mdns4
  4. Install the "winbind" package: sudo apt-get install winbind
    (Or via Software Center or Synaptic.)
  5. Reboot or restart your network.
Eliah Kagan
  • 119,640
nejode
  • 501
I had this problem and solved it by installing the package gvfs-bin. Except for gvfs-bin, most of the gvfs packages were already installed: gvfs, -common, -libs, -daemons, and -backends.
Tom
I had the same problem in Ubuntu 18.04 and this solution worked for me.
  1. Edit /etc/samba/smb.conf and add the line client max protocol = NT1 after the workgroup = WORKGROUP entry.
  2. Restart the samba service by running sudo service smbd restart.
nwaweru
  • 291
I had this issue recently when connecting from Ubuntu 20.04 to a Synology NAS.
The issue seemed to be caused by the software only providing SMB2 and SMB3 versions of the protocol.
When I set the share to support SMB1 (so version 1 to 3 supported) it worked.
In general the issue might be caused by the Samba settings that configure the protocol version and settings and the ones on the server side, so make sure they match.
You may need to install samba:
sudo apt install samba
Flimm
  • 44,031
My problem was due to /etc/samba/smb.conf. Searched for WORKGROUP and deleted the line after it which mentioned a localhost name. Make sure the WORKGROUP is the same for both config files on each machine. An all round way is to sudo apt-get purge samba (and/or remove ?) and then sudo apt-get install samba. This is how I solve the problem the first time round, after upgrading from 16.10 to 17.04 on one of my machines (16.10 was buggy for me). I have two machines now: 16.04 and 17.04.
-1
I could only see my samba server by ip address.
Switching bcast to 1st in 'name resolve order = bcast lmhosts hosts wins'. And restarting samba. Btw this 1 line restarts samba.
sudo service samba restart
That didn't work either.
I went to look in /etc/samba/lmhosts to check it & no file! So I made lmhosts.
$ sudo nano /etc/samba/lmhosts
10.0.2.2   server_name
I still couldn't search the server name. Then I thought wait, the computer name & samba name are different. So I edited hosts & hostname, changing them to the samba server's name. Careful hostname only has one word in it. The computer name no # comments.
/etc/hosts
/etc/hostname
$ sudo reboot
Now it just works. I can just click network in nautilus or caja and the server just pops up! On all clients, all are linux or android. Even on an old debian squeeze machine.
Ned
