To remove the file:// prefix from the URL, you can use sed:
echo "file:///home/user/path/file" | sed "s/^file:\/\///g"
What the above does:
- Displays the URL to the standard output (so it can be modified with sed)
- Replaces all occurrences of
file:// in any line that begins with file:// with nothing. This effectively removes file:// from the URL leaving only /home/user/path/file
To use this from a script you can try the following:
cat $(echo "file:///home/user/path/file" | sed "s/^file:\/\///g")
Now the error message is:
cat: /home/user/path/file: No such file or directory
(Please note that it refers to the correct filename instead of the URL.)
It would be much cleaner to store the converted filename in a shell variable and use it afterwards.
MYFILE=$(echo "file:///home/user/path/file" | sed "s/^file:\/\///g")
cat $MYFILE
