I am trying to do a fresh install of Ubuntu 15.10 on my Asus X205 from a live USB. During the installation I get following error: "The 'grub-efi-amd64-signed' package failed to install into /target/. Without the GRUB boot loader, the installed system will not boot." After klicking "ok" a prompt tells me, that the installation crashed and then the installation stops.
I already had 3 tries and every time I have the same problem.
During my search I found following thread: https://bugs.launchpad.net/ubuntu/+source/grub-installer/+bug/1509620
The person gets the same error and has solved the problem by installing with terminal. Unfortunately I cannot find a hint how to freshly install ubuntu via terminal.
Does anybody know how it works, which commands I need and if I can do it from a normal Live USB or if I need something special?
Mareiqe
I tried to install grub manually as described in this thread: https://superuser.com/questions/376470/how-to-reinstall-grub2-efi My Laptop has already partitions etc as the installation went to the grub-installation point. But still I couldn't install grub-efi-amd64 or grub-efi.
I figured out that I need to install grub-efi-ia32 instead of -amd64. After installing grub-efi-ia32, I didn't know how to (re)install Ubuntu without deleting and reinstalling grub etc. I searched for solutions and learned that Ubuntu 15.10 comes with UEFI-support for the 32bit-Version (older Versions had only UEFI-support for 64bit and I installed it on the 32bit system with this instructions https://github.com/lopaka/instructions/blob/master/ubuntu-14.10-install-asus-x205ta.md).
So I followed this instructions 32-Bit UEFI Boot Support including this step 32bit UEFI better support than a year ago? to make a bootable 32bit-Version USB and to install Ubuntu on the Asus X205.
The installation went fine. Now I am stuggling with LUKS encryption but that is another problem.
Mareiqe
