I've been trying for some time to fix a mistake I have made around a month ago with Windows 8 after installing Xubuntu beside it. In order to make my laptop run GRUB2 instead of the original Windows Boot Loader I edited through command lines using bcdedit on Windows the EFI file paths of the Windows Boot Manager.
After many issues, I had to format my HDD and I could only install a Linux operating system. Windows ones could not, my laptop not even finding a boot file on the Windows recovery disk. I do believe that, since the Windows Boot Manager has different paths that it should have for loading EFI files, it cannot boot any Windows anymore. I have attempted with windows 7, 8 and 10 on disks and USB keys.
By the way, I have attempted to boot Windows disks by using VirtualBox using the physical HDD. When in non-EFI mode, the installation software runs well but refuses to install anything because of the disk's format. When in EFI mode, being my HDD's, it freezes before launching.
I have seen posts about rEFInd and boot-repair but before trying these out I'd love to know if someone could reply to the question beneath.
Is is possible to manually edit these paths from Ubuntu ? It has to be stored somewhere but I cannot seem to find where.
Solution found with the help of ubfan1 :
I opened a terminal and typed the command bellow to have a list of the UEFI boot entries :
sudo efibootmgr -v
I deleted the Windows Boot Manager entry and another boot entry called "Yes" by typing :
sudo efibootmgr -B {boot_entry} for both.
I rebooted and noticed I no longer had the Windows Boot Loader. I booted into Ubuntu and added it back by typing :
sudo efibootmgr -L "Windows Boot Manager" -l "/EFI/Microsoft/Boot/bootmgfw.efi" -p 1
I then rebooted into Ubuntu and noticed the changes had been made. It was possible once again to boot Windows from any device.
