100
I recently installed the latest Kubuntu (x64) on my work machine as I am trying to migrate away from Windows. Unfortunately I use RDP very frequently to connect to customer's servers and need to be able to copy files across.
I have tried the following packages with no luck:
remmina
rdesktop
xfreerdp
My latest attempt to solve this involved connecting one of my folders to the remote server, here is the command I used to launch rdesktop:
rdesktop -5 -K -r disk:home=/home/dai -r clipboard:CLIPBOARD -r sound:off -x l -P 192.168.0.2 -u "administrator" -p pass
The servers are not all running the same version of Windows, the one I've been trying so far is running Server 2003 R2. Customer servers range from Server 2000 to Server 2008.
I have been googling this but all the solutions I find seem to fail, maybe because almost all the help out there assumes that I am running Gnome.
Edit: Copying and pasting text seems to work just fine, but that's not what I need.
vvvvv
  • 878
Dai
  • 1,101
11 Answers11
169
https://gitlab.com/Remmina/Remmina/issues/243 says that shares show up using Remmina when you also enable sound redirection. To recap, here is what you have to do:
  1. Create a Remmina RDP connection to the windows machine
  2. Edit that connection.
  3. Under the Basic tab Choose a share folder
  4. In Advanced tab, change sound to local. Save it and connect
Then the shared folder appears in My computer in windows.
(If it does not appear, trying clicking Refresh).
14
Quoting from the man page (http://linux.die.net/man/1/rdesktop):
-r comport:<comport>=<device>,... Redirects serial devices on your client to the server. Note that if you need to change any settings on the serial device(s), do so with an appropriate tool before starting rdesktop. In most OSes you would use stty. Bidirectional/Read support requires Windows XP or newer. In Windows 2000 it will create a port, but it's not seamless, most shell programs will not work with it.
-r disk:<sharename>=<path>,... Redirects a path to the share \tsclient\ on the server (requires Windows XP or newer). The share name is limited to 8 characters.
Thus, something like this should work:
rdesktop -r disk:sharename=/home/dai -P 192.168.0.2
maniat1k
  • 8,340
It is strange, but rdesktop requires to share disk and sound together:
redsktop -r sound:local -r disk:share=/home/me
Vinci
  • 91
Another option would be (if it is suitable of course) to use shared foler, which you can define in the connection profile of remmina.
Go to connection profile and at the bottom define a folder to share with remote machine.
Eliah Kagan
  • 119,640
Zafar
  • 71
Using remmina (1.2.0), it's an option in the gui:
  • Edit your connection
  • Check on 'Share folder' and select one folder in the host.
muru
  • 207,228
eleuteron
  • 161
with xfreerdp:
xfreerdp "/v:hostname.example.com" "/u:myusername" /drive:tmp,/tmp
With KRDC v17.04.3, drives mounted at /media were automatically visible for me in Windows Explorer in a System Folder named media.
1) Open your ~/.local/share/remmina/*.remmina file (backup first) 2) Set absolute path to sharefolder= option 3) Reconnect. Shared folder should be visible in Windows Explorer
d9k
  • 200
Tip: when using rdesktop -r disk:sharename=/home/user/whatever use direct path, using ~/whatever won't work.
-1
In Remmina RDP connection in Windows server and no transfer files.
Easy in software manager just look for file transfer. Like Sshfs - Filesystem client based on SSH File Transfer Protocol Install it.
-1
  1. You could connect to shared windows folders, e.g. with nautilus.
  2. You could setup a Samba Server on your machine and connect to it from the windows machine.
  3. You could setup an FTP Server on one of the Machines and an FTP Client on the other machine.
  4. Most solutions do not depend on whether you use KDE or Gnome or whatever. You can use "Gnome-Programs" in KDE and the other way around.
There is also an openssh for windows which could help you:
sshwindows
Then you could use scp e.g.:
scp sourcehost:/any/directory /any/local/directory
scp /any/local/directory destinationhost:/and/directory
But I did not try that.
Michael K
  • 14,338
