10
I have a file ma.txt and it contains the output of ls -l; when I run the tr command (tr "nik-pc" "root") I get this output:
nik-pc@nik:~$ cat ma.txt
total 52
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar 11 11:33 Desktop
lrwxrwxrwx 1 nik-pc nik-pc    2 Mar  8 22:54 di -> hd
drwxr-xr-x 3 nik-pc nik-pc 4096 Mar 13 13:28 Documents
drwxr-xr-x 7 nik-pc nik-pc 4096 Mar 14 18:21 Downloads
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar 11 09:39 dwhelper
-rw-r--r-- 1 nik-pc nik-pc 2134 Mar 13 17:40 hd
-rw-r--r-- 1 nik-pc nik-pc    3 Mar 13 15:34 m
-rw-r--r-- 1 nik-pc nik-pc    0 Mar 17 19:48 ma.txt
drwxr-xr-x 3 nik-pc nik-pc 4096 Mar 13 14:58 Music
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar  5 12:30 Pictures
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar  5 11:44 Public
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar 13 15:58 sd
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar  5 11:44 Templates
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar  5 11:44 Videos
drwxr-xr-x 2 nik-pc nik-pc 4096 Mar 11 11:33 xdm-helper
nik-pc@nik:~$ tr "nik-pc" "root" < ma.txt
tttat 52
drwxr-xr-x 2 too-tt too-tt 4096 Mar 11 11:33 Desottt
trwxrwxrwx 1 too-tt too-tt    2 Mar  8 22:54 do -> hd
drwxr-xr-x 3 too-tt too-tt 4096 Mar 13 13:28 Dttutetts
drwxr-xr-x 7 too-tt too-tt 4096 Mar 14 18:21 Dtwtttads
drwxr-xr-x 2 too-tt too-tt 4096 Mar 11 09:39 dwhetter
-rw-r--r-- 1 too-tt too-tt 2134 Mar 13 17:40 hd
-rw-r--r-- 1 too-tt too-tt    3 Mar 13 15:34 t
-rw-r--r-- 1 too-tt too-tt    0 Mar 17 19:48 ta.txt
drwxr-xr-x 3 too-tt too-tt 4096 Mar 13 14:58 Musot
drwxr-xr-x 2 too-tt too-tt 4096 Mar  5 12:30 Pottures
drwxr-xr-x 2 too-tt too-tt 4096 Mar  5 11:44 Pubtot
drwxr-xr-x 2 too-tt too-tt 4096 Mar 13 15:58 sd
drwxr-xr-x 2 too-tt too-tt 4096 Mar  5 11:44 Tetttates
drwxr-xr-x 2 too-tt too-tt 4096 Mar  5 11:44 Vodets
drwxr-xr-x 2 too-tt too-tt 4096 Mar 11 11:33 xdt-hetter
At line one it replaced "nik" with "too" and the spelling of "Desktop" became "Desottt".
Why is this? What is logic behind it?
muru
  • 207,228
tr is for translating characters, not for complete words. It can translate sets. In your example you have "nik-pc" as first collection chars, and "root" is another. In fact, k-p is a range, so it includes all chars from k to p. It will match chars one by one, so n will translate to r, i to o, k to o, and whatever else beyond 4th char will be t. That's why you have "Desktop" translated to "Desottt"
You can see it more clearly in this example:
$ echo "ABCDEF" | tr "ABCDEF"  "12"
122222
Here you can see tr set 1 have D in position 4. But set 2 has no position 4, so it will use last position set 2 has to translate.
What you are doing is translating one word into another. What you want to do is use more advanced tool like sed or awk.
For instance,
$ ls -l /etc/passwd | awk '{gsub(/root/,"TEST");print}'
-rw-r--r-- 1 TEST TEST 2575 Feb 29 12:30 /etc/passwd
18
tr translates a string character-wise. It searches the letters from the first set and replaces them by those form the second set.
You had nik-pc as first set. tr expands the k-p part in that to all letters in the range from "k" to "p", so the set is equal to niklmnopc.
Your second set was root.
What tr now does is to search all occurrences of the first character in the (evaluated) first set and replace them with the first character of the second set. When there is no more character in set 2, it simply repeates its last character. See the table below:
n --> r
i --> o
k --> o
l --> t
m --> t
n --> t
o --> t
p --> t
c --> t
So now it's clear why e.g. "Desktop" becomes "Desottt". The behaviour is fully correct and intended this way.
What you're looking for instead can be achieved using sed:
sed 's/nik-pc/root/g' ma.txt
The syntax is this:
sed 's/SEARCH_PATTERN/REPLACE_STRING/FLAGS' INPUT_FILE
So we let it search for the pattern "nik-pc" and replace the entire match with "root". We need to add the "g" flag to enable global replacing. Without that, it would only replace each first match per line.
Byte Commander
  • 110,243
