I have Ubuntu 15.10 with unity installed, and then tried to install gnome 3 a week ago. Everything worked just fine, but after a week i thought i would revert to unity since i liked it better.
First i just logged out, chose unity and then logged in again. This brought me in unity, but with flaws. The top panel was there and the sidebar, but there were no desktop (as in no background image, no items on the desktop even though i know there are some there)
I thought i would uninstall gnome 3, but something must have gone wrong, because now when i get into unity i have a background but still not anything on my desktop, and whenever i try to connect a second screen unity freezes and the cpu goes crazy.
I must have uninstalled some packages and dependencies that should have stayed, but now i dont know how to get it back to be fully functional again
so is there a way to reinstall unity from scratch or just fix it?
Sudo apt-get install -f output:
~$ sudo apt-get install -f
[sudo] password for mads:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
linux-headers-4.2.0-30 linux-headers-4.2.0-30-generic
linux-image-4.2.0-30-generic linux-image-extra-4.2.0-30-generic
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
And sudo apt-get check:
~$ sudo apt-get check
And sudo apt-get install ubuntu-desktop -s
~$ sudo apt-get install ubuntu-desktop -s
ubuntu-desktop : Depends: unity-control-center but it is not going to be installed
First off you need to resolve the issue with the held broken packages, see this Unable to correct problems, you have held broken packages then proceed with the below
Install the ubuntu-desktop package. This should install everything necessary for the 'normal' Unity experience.
If that doesn't work, you can try reinstalling all the dependencies of ubuntu-desktop with
sudo apt-cache depends ubuntu-desktop | grep '[ |]Depends: [^<]' | cut -d: -f2 | tr -d ' ' | xargs sudo apt-get --reinstall install -y
Command borrowed from: Reinstall package and its installed dependencies
Tobias
  • 1,678
