33
openvpn starts fine from the command line using the exact ExecStart= call from the systemd unit file:
/usr/sbin/openvpn --daemon ovpn-server --status /run/openvpn/server.status 10 --cd /etc/openvpn --script-security 2 --config /etc/openvpn/server.conf /run/openvpn/server.pid
ps ax confirms that the process is there:
1634 ?        Ss     0:00 /usr/sbin/openvpn --daemon ovpn-server --status /run/openvpn/server.status 10 --cd /etc/openvpn --script-security 2 --config /etc/openvpn/server.conf --writepid /run/openvpn/
But systemctl start openvpn@server is not successful:
● openvpn@server.service - OpenVPN connection to server
   Loaded: loaded (/lib/systemd/system/openvpn@.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2016-03-17 09:54:52 UTC; 4s ago
     Docs: man:openvpn(8)
           https://community.openvpn.net/openvpn/wiki/Openvpn23ManPage
           https://community.openvpn.net/openvpn/wiki/HOWTO
  Process: 1679 ExecStart=/usr/sbin/openvpn --daemon ovpn-server --status /run/openvpn/server.status 10 --cd /etc/openvpn --script-security 2 --config /etc/openvpn/server.conf --writepid /run/openvpn/s
 Main PID: 819 (code=exited, status=1/FAILURE)
Mar 17 09:54:52 vpn ovpn-server[1679]:   push_ifconfig_ipv6_remote = ::
Mar 17 09:54:52 vpn ovpn-server[1679]:   enable_c2c = DISABLED
Mar 17 09:54:52 vpn ovpn-server[1679]:   duplicate_cn = DISABLED
Mar 17 09:54:52 vpn ovpn-server[1679]:   cf_max = 0
Mar 17 09:54:52 vpn ovpn-server[1679]:   cf_per = 0
Mar 17 09:54:52 vpn ovpn-server[1679]:   max_clients = 1024
Mar 17 09:54:52 vpn systemd[1]: openvpn@server.service: Control process exited, code=exited status=1
Mar 17 09:54:52 vpn systemd[1]: Failed to start OpenVPN connection to server.
Mar 17 09:54:52 vpn systemd[1]: openvpn@server.service: Unit entered failed state.
Mar 17 09:54:52 vpn systemd[1]: openvpn@server.service: Failed with result 'exit-code'.
I interpret journalctl | grep ovpn-server | tail -n 100 that it failed to fork:
Mar 17 09:57:44 vpn ovpn-server[1693]: OpenVPN 2.3.10 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Feb  2 2016
Mar 17 09:57:44 vpn ovpn-server[1693]: library versions: OpenSSL 1.0.2g  1 Mar 2016, LZO 2.08
Mar 17 09:57:44 vpn ovpn-server[1693]: daemon() failed or unsupported: Resource temporarily unavailable (errno=11)
Mar 17 09:57:44 vpn ovpn-server[1693]: Exiting due to fatal error
I've been looking for a fix for this also. What I have found to work is to comment out the LimitNPROC line in /lib/systemd/system/openvpn@.service.
Don't forget to run systemctl daemon-reload after that.
ki9
  • 546
Iain
  • 576
21
It's better to avoid modyfying systemd units originating from system packages. Just use systemd override drop-in:
systemctl edit openvpn@
Unit name for openvpn server might be different, eg. for package version 2.4.5-xenial0 it will be
systemctl edit openvpn-server@
Then put into editor:
[Service]
LimitNPROC=infinity
It should create /etc/systemd/system/openvpn@.service.d/override.conf file (or similar for corresponding unit name). To activate it you may want to reload systemd with
If starting the unit is successful with LimitNPROC=infinity then go back and change the limit to a higher value than the default of 10. The limit is important to prevent the service from consuming all available pids which can cause a denial of service.
Credits:
override: https://unix.stackexchange.com/a/398541/218321
"unlimited limit": https://unix.stackexchange.com/a/345596/218321
Ryan
  • 25
porbas
  • 361
I also had to add those bellow their respective tun brother
DeviceAllow=/dev/net/tap rw
DeviceAllow=/dev/net/tap1 rw
to run it on L2 level.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Thomas
