I'm really confused how to make my Apache2 web server public. I've setup everything and when I type localhost:80 it comes up properly. But, I need very clear and detailed instructions on how to make it public! And also have it used by its alias which I set to pcpcpc12.com
[EDIT]
Output of /var/log/apache2/access.log
127.0.0.1 - - [16/Mar/2016:20:04:23 +0000] "GET / HTTP/1.1" 200 3594 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:04:23 +0000] "GET /icons/ubuntu-logo.png HTTP/1.1" 200 3688 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:04:24 +0000] "GET /favicon.ico HTTP/1.1" 404 498 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:10:34 +0000] "GET / HTTP/1.1" 200 661 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:10:34 +0000] "GET /icons/blank.gif HTTP/1.1" 200 430 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:10:34 +0000] "GET /icons/folder.gif HTTP/1.1" 200 507 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:10:40 +0000] "GET /pcpcpc12.com/ HTTP/1.1" 200 3594 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:11:31 +0000] "GET /pcpcpc12.com/ HTTP/1.1" 200 732 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:11:31 +0000] "GET /icons/back.gif HTTP/1.1" 200 498 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:11:31 +0000] "GET /icons/blank.gif HTTP/1.1" 304 178 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:11:31 +0000] "GET /icons/folder.gif HTTP/1.1" 304 178 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:11:42 +0000] "GET /pcpcpc12.com/public_html/ HTTP/1.1" 200 280 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:14:26 +0000] "GET /pcpcpc12.com/ HTTP/1.1" 200 734 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:14:26 +0000] "GET /icons/blank.gif HTTP/1.1" 304 178 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:14:26 +0000] "GET /icons/back.gif HTTP/1.1" 304 178 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:14:26 +0000] "GET /icons/folder.gif HTTP/1.1" 304 178 "http://localhost/pcpcpc12.com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:14:44 +0000] "GET / HTTP/1.1" 200 280 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:51:41 +0000] "GET / HTTP/1.1" 200 548 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:51:42 +0000] "GET /favicon.ico HTTP/1.1" 404 498 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
127.0.0.1 - - [16/Mar/2016:20:51:45 +0000] "GET /pcpcpc12.com/public_html/index_two.html HTTP/1.1" 200 505 "http://localhost/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:35.0) Gecko/20100101 Firefox/35.0"
Output of error.log
[Wed Mar 16 19:18:41.713986 2016] [mpm_event:notice] [pid 4282:tid 140223239657344] AH00489: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Wed Mar 16 19:18:41.714259 2016] [core:notice] [pid 4282:tid 140223239657344] AH00094: Command line: '/usr/sbin/apache2'
[Tue Jan 01 00:00:48.990306 2013] [mpm_event:notice] [pid 1316:tid 140375846848384] AH00489: Apache/2.4.7 (Ubuntu) configured -- resuming normal operations
[Tue Jan 01 00:00:49.019771 2013] [core:notice] [pid 1316:tid 140375846848384] AH00094: Command line: '/usr/sbin/apache2'
d a i s y
  • 5,551
when you "set the alias to pcpcpc12.com", others will not be able to view it unless you create a public DNS record. this will require knowing your public IP address. you can just google "what's my public IP"
If you own pcpcpc12.com, registered through godaddy or someone, then they should have an interface for you to create an A host record, use your public IP for that.
If you don't own the domain, then others can still reach your website by typing your public IP address in their browser, for example, http://192.168.0.1/ (your public IP will not start with 192.168)
since you mentioned in the comments that you are using a TalkTalk home gateway router, I'm assuming you're using a residential internet connection. Depending on your ISP, such as Cox (my beloved ISP), they may choose to block your public http port as an incentive to get you to upgrade to a costly business internet connection.
You can check by going away from home somewhere on some other network, and running network map. Install the utility sudo apt-get install nmap and then run the command nmap -Pn -p 80 192.168.0.1 and change the 192.168.0.1 IP to the public IP from step one. With luck, you'll get an open scan like this:
Starting Nmap 6.40 ( http://nmap.org ) at 2016-03-22 22:17 CDT
Nmap scan report for 192.168.0.1
Host is up (0.0028s latency).
PORT   STATE SERVICE
80/tcp open  http
Nmap done: 1 IP address (1 host up) scanned in 0.13 seconds
Otherwise, you'll get a filtered scan like this:
Starting Nmap 6.40 ( http://nmap.org ) at 2016-03-22 22:19 CDT
Host is up.
PORT   STATE    SERVICE
80/tcp filtered http
Nmap done: 1 IP address (1 host up) scanned in 2.58 seconds
In this case, then others can still reach you on a non-blocked port. 8080 is a popular choice. you will need to adjust the settings in your router to port forward map your incoming external port 8080 to your internal port 80 of the internal IP of your server. You will only have one public IP, but you will have a different internal IP for every device on your network. Internal network IPs usually start with 192.168. or 10. You can find out your internal IP by running the terminal command ifconfig
Once you have that setup correctly, then the world will be able to reach your site at http://192.168.0.1:8080, again making sure to use your public IP and not the 192.168.
Jeff Puckett
  • 1,821
As a newbie Linux user, I was also lost trying to understand how to make an Apache website public on my VPS. Here's a complete tutorial I about how to make an Apache website public available that should answer your question and hopefully help future newbies as well.
Prerequisites
This tutorial assumes you already have the following:
  • VPS from a host like Bluehost or AWS (whatever)
  • Ownership of a public domain name
In my situation, I have a Linux VPS with OVH.com, and I own a domain with name.com. Notice this is 2 different companies; hence two different servers.
Detailed Steps
Set up a website on Apache2
Start by setting up your website on your VPS.
Note: This portion of the tutorial isn't about configuring your Linux VPS. I assume you have it ready to go for production.
  1. Create a directory for your website
    Open a terminal and create a directory for your website. Replace domain.com in all steps below with the name of your site:
    mkdir -p /var/www/domain.com/public_html
    Make folder writable to avoid issues further down the road:
    chmod -R 755 /var/www
  2. Create an index page for testing
    gedit /var/www/domain.com/public_html/index.html
    And add something like testing for domain.com.
    Note: If you experience connection issues opening gedit, open other terminal and, as a regular user, run the command xhost +. After that, try running gedit again. For more info about this issue please see here.
  3. Copy default config to a new file:
    cp /etc/apache2/sites-available/000-default.conf /etc/apache2/sites-available/domain.com.conf
  4. Edit the new config file
    gedit /etc/apache2/sites-available/domain.com.conf
    Add/edit the following:
    <VirtualHost *:80>
    ServerAdmin admin@example.com
    ServerName domain.com
    ServerAlias www.domain.com
    DocumentRoot /var/www/domain.com/public_html
    ErrorLog ${APACHE_LOG_DIR}/error.log
    CustomLog ${APACHE_LOG_DIR}/access.log combined
    </VirtualHost>
    Important: The ServerAlias is the name you want people to use to access your Apache website on the internet.
  5. Enable the new config file
    By default, Apache is set to read 000-default.conf file. However in our previous step we made a new config file. So we need to disable the default and enable the new one we created.
    a2dissite 000-default.conf
    a2ensite domain.com.conf
Making Website Public
To make your Apache website public, we need to configure DNS servers.
  1. Log into your VPS
    Login to your VPS account. In my case, I use ovh.com for Linux VPS, but yours may be different. Login to your account and take note of the IP address usually found the under IPv4 settings. Copy to clipboard.
  2. Log into your cpanel
    In my situation, I'm paying two different companies. One for VPS and other one for domains. This is because my VPS provider which I've been using for many years does not sell domains, just private servers. You can skip this step if both your VPS and domain are with the same provider.
  3. Create DNS
    In your account where your domain is, click on Manage DNS or something similar. Click on add new record. This should look something similar to photo below:
    Fill in the fields:
    Host: Use the ServerAlias setting from above.
    Answer: Enter or paste your VPS IP that we previously copied.
  4. Save the record
Voila! Visit your Apache website online and you should see testing for domain.com or whatever you wrote to test the page.
Next Steps: SSL for Apache
At this point, your domain will be HTTP. This will render your Apache website insecure and cause a warning in the browser. We certainly do not want to scare your visitors away with that!
To provide SSL/TLS (HTTPS), I recommend Certbot.
I will not go in details about how to do this, but visit their site. The tutorial is pretty straightforward.
NotTheDr01ds
  • 22,082
Grogu
  • 117
