I have an Acer laptop (E1-571) that came pre-installed with Windows 8. I then installed Ubuntu 14.04 to double boot alongside Win 8. Now, I want to get rid of my Windows installation and single boot Ubuntu 14.04.
I am stuck when it comes to partitioning my 500 GB hard disk. I made a swap partition of 4 GB, another 100 GB partition for /home and 25 GB for /. This rendered the remaining 368 GB useless - I cant save files to it and it's completely empty.
Suppose I have to start the partitioning from scratch, how do I do it? Can someone guide me right from setting partitions as logical/primary/extended to fixing mount points and boot? I know that I have to boot from the Live USB and use GParted. I've done this once before so I don't know why this is screwed up.
If you want to use only Ubuntu and no Windows then you can let the partitioner do its job.
If you really want to partition manually then this is the generally accepted norm
  • Set an equal amount of space for your swap partition as your ram. Set the mount point as swap
  • set around 1GB for the /boot partition. Mount point is /boot
  • set the rest for /
This config works for most cases.
sohom154
  • 103
