I'm a newcomer to Ubuntu, and have just installed version 15.10 (64 bit) alongside Windows 10. All seems to have gone well, but I can't boot Ubuntu from Grub. I've checked the install from a live USB, and all appears ok (to my novice eyes). Do I have to configure Grub in anyway, or have I inadvertantly installed the boot loader on an incorrrect partition? I would be grateful for any advice, and apologise if this topic has already been covered previously.
try boot repair
- either from an Ubuntu live-session (boot your computer on a Ubuntu live-CD or live-USB then choose "Try Ubuntu") or from your installed Ubuntu session (if you can access it)
connect to the Internet
open a new Terminal, then type the following commands (press Enter after each line):
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
Using Boot-Repair Recommended repair
- launch Boot-Repair from either :
- the Dash (the Ubuntu logo at the top-left of the screen)
- or by typing 'boot-repair' in a terminal
- Then click the "Recommended repair" button. When repair is finished, note the URL (paste.ubuntu.com/XXXXX) that appeared on a paper, then reboot and check if you recovered access to your OSs.
- If the repair did not succeed, indicate the URL to people who help you by email or forum.
Warning: the default settings are the ones used by the "Recommended Repair". Changing them may worsen your problem. Don't modify them before creating a BootInfo URL, and asking for advice on Ubuntu Forums Absolute Beginners Section or in Installation and Upgrades.
more info here boot repair
- 11
This is probably cause the windows bootloader loads first and doesn't let grub to load.
So try this. It should work. After you power-on the system press esc (or whatever key based on you computer) to pause startup and go to the boot options or BIOS (for non-UEFI systems).
There you will find the "Startup Menu". In this menu press the appropriate function key to select the " boot device option".
Selecting this will take you to a menu where you will see all the available boot devices. Some of the options will be :-
- OS boot manager
- Boot from EFI file
- Notebook Hard drive
- network adapter
Now if you have installed correctly then there should be another option called ubuntu...blah blah blah...
Select that and grub should load properly.
- 103
