I'm trying to set the system time to UTC such that when I log in and run date, or run programs that ask for the current time (say, python -c 'import datetime; print datetime.datetime.now()'), they return times in UTC. Based on searching and https://askubuntu.com/a/524362, I expect that when I run
sudo timedatectl set-timezone UTC
the system time will be set to UTC. That program exits with 0 when I run it and timedatectl status prints the following output:
$ timedatectl status
      Local time: Wed 2016-03-16 14:31:50 UTC
  Universal time: Wed 2016-03-16 14:31:50 UTC
        RTC time: Wed 2016-03-16 14:31:49
       Time zone: UTC (UTC, +0000)
 Network time on: yes
NTP synchronized: yes
 RTC in local TZ: no
However, when I log out, log back in, and run date, I still get a value in EDT:
$ date
Wed Mar 16 10:31:32 EDT 2016
What am I doing wrong?
Efren
  • 145
Kevin Burke
  • 134
If you don't mind getting an interactive application,
$ sudo dpkg-reconfigure tzdata.
As to why the timedatectl failed, see the GUI time/date configuration option in System Settings. It is possible that some Use network time setting is blocking it.
Another alternative method is:
$ sudo ln -sf /usr/share/zoneinfo/Etc/GMT$offset /etc/localtime, where $offset is the offset from GMT(UTC) time. Since, you want UTC,
$ sudo ln -sf /usr/share/zoneinfo/Etc/GMT /etc/localtime.
