-1
When I try to update:
sudo apt-get update
W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/Release  Unable to find expected entry 'main/binary-i386/Packages' in Release file (Wrong sources.list entry or malformed file)
E: Some index files failed to download. They have been ignored, or old ones used instead. Also every time that I get new updates from Software & Updates it fails. How can I work to fix this issue?
And I'm not sure how to fix it using this solution.
naman
  • 35
Open the terminal CTRL + ALT + T and use this code:
sudo sed -i -e 's/deb http/deb [arch=amd64] http/' "/etc/apt/sources.list.d/google-chrome.list"
Google has dropped support for 32-bit system. Your problem is about that. You can use that code for fix this error.
But please search your problem first, if it doesn't exist, you can open a new question.
