Today in class we found that after installing Ubuntu, the Wi-Fi doesn't work. The Wi-Fi LED stays orange (Blue means it works).
  • Where I can found the drivers?
  • What should I do in the CLI when we have the drivers?
Ubuntu's are: 14.4, 14.10, 15.4 & 15.10 (All have versions of x86 & x64) Laptop is HP 6735s
WLAN Device is Broadcom bcm4312 [14e4:4315]
Thanks for attention.
andrew.46
  • 39,359
  • Insert your Ubuntu instalation media(usually the USB flash drive)
  • Go to pool>main>d>dkms and copy the .deb file to a New Folder on your Desktop
  • Then go to pool>restricted>b and copy the .deb file to the same folder as dkms file(previous step)
  • Open a terminal and using cd command navigate to the New Folder
  • Run sudo dpkg -i dkms*.deb and sudo dpkg -i bcmwl*.deb and done, your driver should work now or after a reboot.
Daniel
