I want to disable suspend because my VPS goes into suspend and I cannot access it.
How I can do that?
Aaron
  • 6,764
On Ubuntu 16.04 LTS, I successfully used the following to disable suspend:
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
And this to re-enable it:
sudo systemctl unmask sleep.target suspend.target hibernate.target hybrid-sleep.target
-1
You can use gconf-editor
install that with
sudo apt-get install gconf-editor
and then look at
/apps/gnome-power-manager/timeout
Try setting sleep_computer_ac to 0
maybe help
Mahdi
  • 1,482
-1
This could have to do with that you are trying to run a bash script and that when you close your terminal it just quits this script, this is quite easy to solve.
Step 1 (install screen if not already installed)
sudo apt-get install screen
Step 2 (using it!)
Now before you run your script just run screen!
If you want to get back to it later try running screen -R
I hope this helped!
