Brother Printer HL-1112: Driver-Set Up (linux-brprinter-installer-2.0.0-1.gz) This Driver is from Brother-Web-page.
How can I install it in the Linux-System ??
Another way: Install Brother drivers from their website: http://support.brother.com/g/b/downloadtop.aspx?c=us_ot&lang=en&prod=hl1112_us_eu
hl1110lpr hl1110cupswrapper
Then ensure that also installed are:
brother-lpr-drivers-common brother-lpr-drivers-laser1 brother-cups-wrapper-common brother-cups-wrapper-laser1 printer-driver-brlaser
Probably not all these five are necessary (you could experiment) but together they made my printer work.
Assuming the download is in your ~/Downloads directory
cd ~/Downloads
gunzip linux-brprinter-installer-2.0.0-1.gz
sudo -i
bash linux-brprinter-installer-2.0.0-1
Answer the questions it shows (printer model and type of connection are the 1st two) and wait for the installer to continue. Watch for error notices.
If all goes well check "Printers" and see if your model is listed and the let CUPS install it.
Requirements:
The tar file only has 1 file in it and has some parameters you can change:
ENABLE_FAX_INSTALL=No # change to Yes if FAX is required
DEBUG_MSG=0
MSG=1
1) Right-click it. After it opens in Archive Manager, extract it to wherever you want
2) Open a terminal (CTRL + ALT + T)
3) cd to where you extracted the file.
4) sudo su - Type your password
5) chmod +x linux-brprinter-installer-2.0.0-1
6) ./linux-brprinter-installer-2.0.0-1
