11
Is there any shortcut for it?
If not is it possible to set a key for this operation?
I am using Ubuntu 14.04 LTS.
kos
  • 41,268
alhelal
  • 2,741
yes you can using Ctrl + D as you can see in this page under the Shortcut keys for editing files: Gedit shortcut keys
Yes. Position the cursor anywhere on the line you wish to delete and hit CTRL+D.
Apparently the shortcut is simply built-in into Gedit. I can't find an easy way to change it; apparently that's technically not possible [anymore], or at least not easily.
kos
  • 41,268
Have a look here
It is Delete the current line: CTRL+D.
cmks
  • 1,914
For anything related to text in general:
Use Home to put the cursor at the beginning of the line then Shift+End+backspace
Similarly you can set the cursor at the end using End then Shift+Home+backspace
techraf
  • 3,316
