13
Ubuntu 14.04:
I've downloaded the latest imagemagick source and installed, using option below to configure:
root@usve59445:~/im/ImageMagick-6.9.3-7# ./configure --enable-shared --with-png=yes
After installation however, I have zero items in my built-in list of delegates:
root@usve59445:~/im/ImageMagick-6.9.3-7# identify -version
Version: ImageMagick 6.9.3-7 Q16 x86_64 2016-03-14
Copyright: Copyright (C) 1999-2016 ImageMagick Studio LLC License:
Features: Cipher DPC OpenMP
Delegates (built-in):
Issue I am getting is 'no delegate for format PNG found' when doing a convert command.
I installed the libpng delegate from: http://www.imagemagick.org/download/delegates/
Extracted the libpng1621.tar.gz into its own folder, then: Ran configure, make, make install (no error messages)
Now when I try and recompile imagemagick, it still says ' Checking for PNG ... no' and --with-png value has 'no' (even though I configure it with --with-png=yes ).
Not sure what I am doing wrong?
Trying to recompile IM using:
root@usve59445:~/im/ImageMagick-6.9.3-7# ./configure --enable-shared=yes --with-png=yes LDFLAGS='-L/usr/local/lib' LIBS=-lpng16
(I think I am using the correct LDFLAGS, but not sure)
root@usve59445:~/im/libpng-1.6.21# libpng16-config --L_opts
-L/usr/local/lib
root@usve59445:~/im/libpng-1.6.21# libpng16-config --libs
-lpng16
root@usve59445:~/im/libpng-1.6.21# locate libpng
/lib/x86_64-linux-gnu/libpng12.so.0
/lib/x86_64-linux-gnu/libpng12.so.0.46.0
/usr/bin/libpng-config
/usr/bin/libpng12-config
/usr/include/libpng
/usr/include/libpng12
/usr/include/libpng12/png.h
/usr/include/libpng12/pngconf.h
/usr/lib/x86_64-linux-gnu/libpng.a
/usr/lib/x86_64-linux-gnu/libpng.so
/usr/lib/x86_64-linux-gnu/libpng.so.3
/usr/lib/x86_64-linux-gnu/libpng12.a
/usr/lib/x86_64-linux-gnu/libpng12.so
/usr/lib/x86_64-linux-gnu/libpng12.so.0
/usr/lib/x86_64-linux-gnu/pkgconfig/libpng.pc
/usr/lib/x86_64-linux-gnu/pkgconfig/libpng12.pc
/usr/local/bin/libpng-config
/usr/local/bin/libpng16-config
/usr/local/include/libpng16
/usr/local/include/libpng16/png.h
/usr/local/include/libpng16/pngconf.h
/usr/local/include/libpng16/pnglibconf.h
/usr/local/lib/libpng.a
/usr/local/lib/libpng.la
/usr/local/lib/libpng.so
/usr/local/lib/libpng16.a
/usr/local/lib/libpng16.la
/usr/local/lib/libpng16.so
/usr/local/lib/libpng16.so.16
/usr/local/lib/libpng16.so.16.21.0
/usr/local/lib/pkgconfig/libpng.pc
/usr/local/lib/pkgconfig/libpng16.pc
/usr/local/share/man/man3/libpng.3
/usr/local/share/man/man3/libpngpf.3
/usr/share/doc/libpng12-0
/usr/share/doc/libpng12-dev
/usr/share/doc/libpng3
/usr/share/doc/libpng12-0/ANNOUNCE
/usr/share/doc/libpng12-0/KNOWNBUG
/usr/share/doc/libpng12-0/README.Debian
/usr/share/doc/libpng12-0/README.gz
/usr/share/doc/libpng12-0/TODO
/usr/share/doc/libpng12-0/changelog.Debian.gz
/usr/share/doc/libpng12-0/copyright
/usr/share/doc/libpng12-0/libpng-1.2.46.txt.gz
/usr/share/doc/libpng12-dev/changelog.Debian.gz
/usr/share/doc/libpng12-dev/copyright
/usr/share/doc/libpng12-dev/examples
/usr/share/doc/libpng12-dev/examples/example.c.gz
/usr/share/doc/libpng12-dev/examples/pngtest.c.gz
/usr/share/doc/libpng12-dev/examples/pngtest.png
/usr/share/doc-base/libpng12
/usr/share/man/man1/libpng-config.1.gz
/usr/share/man/man1/libpng12-config.1.gz
/usr/share/man/man3/libpng.3.gz
/var/cache/apt/archives/libpng12-0_1.2.46-3ubuntu4.2_amd64.deb
/var/cache/apt/archives/libpng12-dev_1.2.46-3ubuntu4.2_amd64.deb
/var/cache/apt/archives/libpng3_1.2.46-3ubuntu4.2_amd64.deb
/var/lib/dpkg/info/libpng12-0:amd64.list
/var/lib/dpkg/info/libpng12-0:amd64.md5sums
/var/lib/dpkg/info/libpng12-0:amd64.postinst
/var/lib/dpkg/info/libpng12-0:amd64.postrm
/var/lib/dpkg/info/libpng12-0:amd64.shlibs
/var/lib/dpkg/info/libpng12-dev.list
/var/lib/dpkg/info/libpng12-dev.md5sums
/var/lib/dpkg/info/libpng3:amd64.list
gvanto
  • 333
You are making things a little too hard for yourself, here is a quick and dirty guide that ran well for me on Trusty Tahr:
First pick up a few known dependencies:
sudo apt-get install build-essential checkinstall \
             libx11-dev libxext-dev zlib1g-dev libpng12-dev \
             libjpeg-dev libfreetype6-dev libxml2-dev
This does not quite catch everything so activate the Source repositories by clicking on 'Souce Code' here:
Dash >> Software & Updates >> Source Code
and then running the following:
sudo apt-get build-dep imagemagick
Create a build folder and change to it:
mkdir $HOME/imagemagick_build && cd $HOME/imagemagick_build
And finally download, extract, compile and install by simply copying and pasting the entire code box below into a Terminal window:
wget https://www.imagemagick.org/download/ImageMagick-7.0.8-28.tar.bz2 && \
tar xvf ImageMagick-7.0.8-28.tar.bz2 && cd ImageMagick-7.0.8-28 && ./configure && make && \
sudo checkinstall -D --install=yes --fstrans=no --pakdir "$HOME/imagemagick_build" \
     --pkgname imagemagick --backup=no --deldoc=yes --deldesc=yes --delspec=yes --default \
     --pkgversion "7.0.8-28" && \
make distclean && sudo ldconfig
And finally test this, looking especially for the png you are missing in your own install:
andrew@corinth:~$ identify -version
Version: ImageMagick 7.0.5-10 Q16 x86_64 2017-06-05 http://www.imagemagick.org
Copyright: Copyright (C) 1999-2017 ImageMagick Studio LLC
License: http://www.imagemagick.org/script/license.php
Delegates (built-in): bzlib djvu fftw fontconfig freetype jbig jng jpeg lcms lqr lzma openexr pangocairo png tiff wmf x xml zlib
andrew@corinth:~$
And there is the png option you were missing :).
vwvw
  • 129
andrew.46
  • 39,359
I installed ImageMagick7.0.11 as well as ImageMagick7.1.0 by extracting it's tar.gz files. But it did not work. Finally I had to install it using the rpm only. The 'dnf' command does the trick for you. If apt-get is not working, then 'dnf' might be the right solution for your RHEL/CentOS 8. Check this link for reference - https://unix.stackexchange.com/questions/555466/how-to-install-apt-get-and-dpkg
Now, when I hit the magick -version or convert -
version command, I can see this output which is correct: Version:
ImageMagick 7.0.11-13 Q16 x86_64 2021-05-17 https://imagemagick.org Copyright: (C) 1999-2021 ImageMagick Studio LLC License: https://imagemagick.org/script/license.php Features: Cipher DPC HDRI Modules OpenMP(4.5) Delegates (built-in): bzlib cairo djvu fontconfig freetype gslib jng jp2 jpeg lcms ltdl lzma openexr pangocairo png ps raqm raw rsvg tiff webp wmf x xml zlib
Initially, for me too, this 'Delegates(build-in)' section was coming blank, when I kept trying hard using yum command.
andrew.46's answer provides solution for building correctly on any debian-like distro, but does not really answer why the original poster's build was not finding libpng.
Easy way to find the culprit is to run pkg-config --cflags libpng as follows
user@mac ~ % pkg-config --cflags libpng
Package zlib was not found in the pkg-config search path.
Perhaps you should add the directory containing `zlib.pc'
to the PKG_CONFIG_PATH environment variable
Package 'zlib', required by 'libpng', not found
This provides insight into what's missing. In my case it was zlib. After installing zlib:
-I/usr/local/include/libpng16 -I/usr/local/include
