Ubuntu 14.04. It detects wired connections but can't get an IP address. I've tried it with different wired networks and each time had the same problem, both with nm-applet and wicd. My other computer connects to my home network without a problem.
It's not blocked, soft or hard. I tried the suggestion here but it didn't change anything. One thing to note is that cable does not connect directly to the laptop but through a proprietary connector. Here is the output of ifconfig:
eth0      Link encap:Ethernet  HWaddr 24:f5:aa:c2:58:c7
          inet6 addr: fe80::26f5:aaff:fec2:58c7/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:378 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:8058 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8058 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:2163118 (2.1 MB)  TX bytes:2163118 (2.1 MB)
wlan0     Link encap:Ethernet  HWaddr 6c:29:95:19:08:1b
          inet addr:192.168.1.133  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::6e29:95ff:fe19:81b/64 Scope:Link
          RX packets:2280079 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1500378 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2912209727 (2.9 GB)  TX bytes:186227404 (186.2 MB)
Here is the contents of /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
Here is the output of sudo lspci -vvnn | grep -iA 10 ethernet.
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
    Subsystem: Samsung Electronics Co Ltd Device [144d:c109]
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 64 bytes
    Interrupt: pin A routed to IRQ 61
    Region 0: I/O ports at e000 [size=256]
    Region 2: Memory at f7c00000 (64-bit, non-prefetchable) [size=4K]
    Region 4: Memory at f0000000 (64-bit, prefetchable) [size=16K]
    Capabilities: [40] Power Management version 3
        Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Reza
  • 1,255
set network configuration manually. for that, follow the below commands:
ifconfig eth0 192.168.31.3 netmask 255.255.255.0 up
(IP and NetMask is example)
sevice networking restart
Byte Commander
  • 110,243
ansar313
  • 159
Add in /etc/network/interfaces
(this is example)
iface eth0 inet static
address 192.168.1.200
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.1
Then
sudo /etc/init.d/networking restart
This way use static IP address.
Junshoong
