I know that similar question was already asked but there are no information about how serious is this message. I mean, does it mean that my ATI 6750 card wasn't really recognized by proprietary driver or it is a bug? In the ubuntu documentation it is written that this card works from box. So I'm a bit confused. PS I installed "AMD/ATI FGLRX proprietary graphic driver" but I can't install "AMD/ATI FGLRX proprietary graphic driver(post release updates)". It returns error
Asked
Active
Viewed 2,504 times
Unsupported Hardware Watermark
This can happen if your card's PCI ID wasn't officially certified to work with a particular version of Catalyst. It does not necessarily mean that your card is unsupported, but it does mean that you shouldn't file bugs with that particular card/driver combination. If you installed the driver by downloading it from AMD/ATI, installing a newer version of Catalyst will probably help.
If you installed the proprietary driver included with Ubuntu or you do not want to upgrade to a newer version, it may be possible to work around the issue by using a control file from a newer version of Catalyst than the one you're running.
cd ~/; mkdir catalyst11.10; cd catalyst11.10/
wget http://www2.ati.com/drivers/linux/ati-driver-installer-11-10-x86.x86_64.run
chmod +x ati-driver-installer-11-10-x86.x86_64.run
sh ati-driver-installer-11-10-x86.x86_64.run --extract driver
sudo mv /etc/ati/control ~/control.bak
sudo cp driver/common/etc/ati/control /etc/ati
