I would like to have a regex that will rename my files. Microsoft Windows has changed my files' names and I want to remove the parenthetical datetime substring from the filenames.
Here are some sample filenames:
My desired filenames after renaming are:
The tutorials that I found didn't do well for me because there are some special characters and numbers.
mickmackusa
  • 852
  • 20
5 Answers5
14
You can use the rename command:
$ rename -n 's/ \(.*?\)//' *.png
s/ \(.*?\)// is a simple, if broad, expression, matching a space followed by parentheses-enclosed stuff. You can pick more precise expressions like:
  • s/ \(.*?\)\.png$/.png/ - like the previous, but matching only if followed by .png and the end of the filename, or
  • s/ \(\d{4}(_\d\d){2} \d\d(_\d\d){2} UTC\)\.png/.png/ - matching the date pattern shown in these files, and followed .png.
The -n option is for testing the command. Run without it if you're satisfied with the results.
muru
  • 207,228
Using bash parameter expansion:
for file in *.png; do mv -i "$file" "${file%% *}".png; done
${file%% *} will discard the unwanted portion of the filename starting from space. Then the extension .png is added after the filename while mv-ing.
heemayl
  • 93,925
You could try the following python code snippet
import os
import glob
files = glob.glob('*')
for file in files:
    var1 = file.find(' (')
    var2 = file.find(')')+1
    filename = file[:var1] +  file[var2:]
    os.rename(file, filename)
  • glob finds all files which satisfy the regex argument
  • You iterate through the list and modify the name of the file
  • rename changes the name of the file
gokul_uf
  • 327
Using bash and parameter expansion, run the following code from the same directory where you have the files.
for file in *.png ; do NAME="${file%%\ \(*}"; EXT="${file##*.}" ; mv "$file" "$NAME"."$EXT"   ; done
Sample run
$> ls
icon-culture (2015_09_04 06_58_44 UTC).png  icon-disk (2015_09_04 06_58_44 UTC).png
$> for file in *.png ; do NAME="${file%%\ \(*}"; EXT="${file##*.}" ; mv "$file" "$NAME"."$EXT"   ; done
$> ls
Assuming all of the files in the directory need to receive the same treatment (IOW, this is a string extraction task and not a string validation task), here is alternative to @muru's solution that mixes some wisedom that I drew from @CandyGumdrop's comprehensive Stackoverflow answer with my understanding of regular expression optimization:
prename 's/ [^.]*//' *
The pattern relies on the consistent substring structure that begins with the only space character in the filename, then greedily consumes all characters that are not a literal dot. Upon matching these characters, the replacement string is a zero-width string (IOW, replace with nothing). If you ever want to insert any characters in place of the matched substring, those characters would be written between the two consecutive forward slashes.
The * at the end of the command says to include all files in the directory. This may be useful if your file types may differ in the future.
One metric for measuring regex pattern efficiency is the number of steps that the regex engine has to take. https://regex101.com does a great job of spelling out pattern logic and presenting the step count.
https://regex101.com/r/JeB581/1/ shows that it takes 64 steps to make the 21 replacements on your provided battery of filenames.
https://regex101.com/r/JeB581/2/ shows that @muru's pattern will require 588 steps to perform the same 21 replacements.
It is entirely possible that there is no reason to quibble over performance, say, if your file count is relatively small. I merely want to point out how to optimize the pattern by taking advantage of greedy quantifiers (*?) versus lazy quantifiers (.*) if/when it is beneficial. The other way to state the pattern difference is that I am sacrificing string validation strength for faster matching.
mickmackusa
  • 852
  • 20
