I followed this Ask Ubuntu guide, I manually downloaded virtual box from this link and tried to install like:
$ dpkg -i virtualbox-5.0_5.0.16-105871~Ubuntu~trusty_amd64.deb
But no success, I got this error:
    dpkg: error processing package virtualbox-5.0 (--install):
 dependency problems - leaving unconfigured
Processing triggers for systemd (219-7ubuntu6) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for hicolor-icon-theme (0.14-0ubuntu1) ...
Processing triggers for shared-mime-info (1.3-1) ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Processing triggers for gnome-menus (3.10.1-0ubuntu5) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu3) ...
Processing triggers for bamfdaemon (0.5.1+15.04.20150202-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.58ubuntu1) ...
 virtualbox-5.0
I got the Oracle Virtual box icon in applications, when i click, it does not open, so geny motion does not recognize any virtual box, so it could not start as well.
Please help me. I have already used
sudo apt-get remove --purge virtualbox*
sudo add-apt-repository "deb http://download.virtualbox.org/virtualbox/debian trusty contrib"
wget -q https://www.virtualbox.org/download/oracle_vbox.asc -O- | sudo apt-key add -
sudo apt-get update && sudo apt-get install virtualbox-5.0
No success. What am I doing wrong?
  • Ubuntu 15.04
  • Java version javac 1.8.0_74
Amul Bhatia
  • 398
  • 14
Although Ubuntu 15.04 is not supported anymore, you can install VirtualBox this way :
First completely remove all traces from the previous VirtualBox installation attempts.
sudo apt-get purge "^virtualbox-.*"
Download and register the ORACLE public key.
wget -q -O - https://www.virtualbox.org/download/oracle_vbox.asc | sudo apt-key add -
Add the VirtualBox repository to the sources.
echo "deb http://download.virtualbox.org/virtualbox/debian vivid contrib" | sudo tee /etc/apt/sources.list.d/oracle-vbox.list
Update the repositories :
sudo apt-get update
Install VirtualBox 5.0 :
Note for other users reading this answer, in case they use another Ubuntu edition as 15.04 :
You have to replace vivid with the Ubuntu edition you are using when adding the repository !
As of Ubuntu 16.04 the ORACLE public key to download and register has changed :
oracle_vbox.asc has to be replaced with oracle_vbox_2016.asc !
cl-netbox
  • 31,491
Download the .deb file from here and then run
sudo dpkg -i <downloaded_file_name>
That should fix your issues
gokul_uf
  • 327
I would not go for AMD package.
  1. Type uname -a in command line.
    OUTPUT:
    Linux christopher 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:31:42 UTC 2014 i686 i686 i686 GNU/Linux
  2. I know AMD is not the one.
  3. Go to this page and select the i386 version
  4. Download and install
