I am new to Ubuntu. while trying to update the vlc in order to be able to play certain videos, I screwed up and now im unable to install a new version of the VLC media player. while doing this, I was using Ubuntu 14.04. I thought it'll be fixed when I upgrade to 15.04 but it didn't help. this is what I get when i try to install vlc through the terminal.
ricky@ricky-pc:~$ sudo apt-get install vlc
[sudo] password for ricky:
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-nox (= 2.2.0+git20160309+r58687+31+14~ubuntu15.04.1) but 2.2.1~trusty1 is to be installed
       Depends: libgles1-mesa (>= 7.8.1) but it is not installable or
                libgles1
       Depends: libva-drm1 (>= 1.1.0) but it is not installable
       Depends: libva-x11-1 (>= 1.0.3) but it is not installable
       Depends: libxcb-composite0 but it is not installable
       Depends: libxcb-xv0 (>= 1.2) but it is not installable
       Recommends: vlc-plugin-notify (= 2.2.0+git20160309+r58687+31+14~ubuntu15.04.1) but it is not going to be installed
       Recommends: vlc-plugin-samba (= 2.2.0+git20160309+r58687+31+14~ubuntu15.04.1) but it is not going to be installed
When I try to install VLC from software center, this message pops up, Package dependencies cannot be resolved.
Please me out. Thanks in advance.
sudo apt-get purge vlc
sudo apt-get update
sudo apt-get upgrade
techraf
  • 3,316
for solving unmet dependency error, you can run these commands:
sudo dpkg --configure -a
sudo apt-get -f install
then, try to install, update,...
Type the following command:
sudo add-apt-repository ppa:mc3man/trusty-media
sudo apt-get update
sudo apt-get install vlc vlc-plugin-*
GAD3R
  • 3,748
-1
Download the latest vlc deb file as per your ubuntu version from http://pkgs.org/download/vlc
Install the package and fetch the repositories using:
sudo gdebi downloadedPackageName.deb
If you already have it installed with missed dependencies, download and install the missing dependencies with
Ishan
