My question is just like this one, except that I need to add a Cinnamon menu item for a single user only. It should be done as a part of the installation process (for an application installed privately in user's home directory) without using sudo.
Asked
Active
Viewed 184 times
maaartinus
- 767
For a single user you can put the desktop entry file in ~/.local/share/applications/
Check out the specification for more info and an example:
https://specifications.freedesktop.org/desktop-entry-spec/desktop-entry-spec-1.0.html
You can also check the location for all users in /usr/share/applications for examples.
Good luck!
E.F. Nijboer
- 1,351
