Using Ubuntu 15
I install Apache and want to add files to the /var/www/html/ directory.
If I type in my browser: file:///var/www/html/ I can see the files (only index.html). However, I cannot add, remove or edit any file.
Is there any way I can access to /var/www/html/ without using the terminal, something similar to Windowns accessing through the Files functionality?
I read that I should be able to do it this way: - Open Nautilus - Goto Filesystem → var → www and now you can add/copy/paste your files.
But If I type in Nautilus, the File cabinet open up and I'm not able to locate Filesystem
Thank you so much
Samuel
You have to run nautilus as root.
gksu is now depreciated so
I believe the proper way to open nautilus as root would be to use sudo -i instead.
Here's an example:
sudo -i nautilus &
Can not install nautilus-gksu in Ubuntu 14.04 LTS
nicandris
  • 399
Simply you don't have permission to write in the folder. Either you should use your file manager as root, or change the permission of the folder to 666
