In 11.10 the ability to write to NTFS drives was removed. There are ways around this, like ntfs-config, which mounts the selected drives as r/w, but I'm looking for a more permanent solution. I have also tried enabling it in the kernel (when compiling) but that doesn't seem to do anything.
tl:dr I want for NTFS drives (including removable ones) to be mounted r/w instead of r/o (from gnome-shell and nautilus), like in 10.10 and 11.04
NRoach44
  • 488
I use NTFS-config and it mounts all me external and internal drives with write capabilities
just run this in commandline after installing ntfs-config
sudo mkdir -p /etc/hal/fdi/policy
this will make ntfs config run and u can enable read write
sarvesh.lad
  • 2,534
am posting the fstab entry for ntfs on my system ...
am able to write Ubuntu 11.10 i386 ...
# /media/NTFS was on /dev/sda3 during installation
UUID=4E842157842142B7 /media/NTFS     ntfs    defaults,umask=007,gid=46                0       0
N.N.
  • 18,589
joe1983
  • 565
I had the same issue. resolved by installing ntfs-config using :
sudo apt-get install ntfs-config
then
I had a problem of dependencies when I used :
sudo aptitude install ntfs-config Don't use aptitude but apt-get
  • Writing in NTFS partition is not possible unless the package ntfs-3g is installed (this latter was removed in ubuntu 11.10 while keeping ntfsprogs instead)
Hanynowsky
  • 2,801
