Tried bunch of stuffs. Now, if someone could suggest a good method I want to uninstall what I installed without effecting windows and do a clean install following the right procedure.
Purpose is to use Ubuntu as platform for developing deep learning Python/C++ applications using NVIDIA GPU (Geforce GTX 950M).
What I did: 1. Created USB stick with Ubuntu 14.04 LTS for installation (at that point I did not know about booting in UEFI mode; all I did was change the order in BIOS). By the way my BIOS is in UEFI mode. 2. Tried installing NVDIA graphics driver and lost GUI screen. Restored it back later though by going to the original driver. 3. Tried number of things to fix the dual boot issue. (If I remember correctly, I think it had worked for the first time and then onwards it does not normally. I can do F9 everytime and then boot either or but I wish to make it through Windows or GRUB boot loader).
Please suggest. Thanks!
EDIT: I believe oldfred's solution and guide will work. I haven't tried it yet but I will update this post as I get that done. (In the mean-time feel free to add in).
stlpro
To boot grub first:
(Usually F1 to enter BIOS) Locate UEFI / Legacy boot order in your BIOS. Set to legacy first. (It seems you have installed Legacy)
If that does not help locate boot order and move your ubuntu disk to the top (Or under USBkey).
If this fails you might consider: https://help.ubuntu.com/community/Boot-Repair
Please read the whole article.
Izzno
  • 944
