my machine has a lot of unused space. Here is the output from the command sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
NAME FSTYPE SIZE MOUNTPOINT LABEL
sda 80G
├─sda1 ext2 243M /boot
├─sda2 1K
└─sda5 LVM2_member 19.8G
├─dist--3--vg-root (dm-0) ext4 15.8G /
└─dist--3--vg-swap_1 (dm-1) swap 4G [SWAP]
sr0 1024M
However, my system only recognizes around 30GB:
ubuntu@slave-2:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/dist--3--vg-root 16G 9.8G 4.8G 68% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
udev 3.9G 4.0K 3.9G 1% /dev
tmpfs 799M 732K 798M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 3.9G 0 3.9G 0% /run/shm
none 100M 0 100M 0% /run/user
/dev/sda1 236M 227M 0 100% /boot
cm_processes 3.9G 316K 3.9G 1% /run/cloudera-scm-agent/process
Now how can I add the unused partition to the normal partition. I don't have access to GUI, only via Terminal.
