I'm trying to install wordpress, and i'm following an article on the web, and one of the steps is:
Now, we need to change the permission of the ‘wordpress‘ directory. Prompt to the wordpress directory in the root directory we just copied and run the following command:
sudo chown -R username:www-data *This command will assign the control of our wordpress directory to www-data user. This is a user web servers used to access the files. In this way the server would be able to write directly to our wordpress directory.
So I change directories, and go into the wordpress dir that's in root, run the command but get this error code:
chown: invalid user: ‘username:www-data’
I'm not sure if I'm supposed to put something other than username (the article it does specify this) or do something else.
