I have installed Ubuntu 14.04 (Trusty Tahr) along with Windows 8.1. When I turn on the computer I don't get an option to boot into Ubuntu, and I go strait into Windows. How can I solve this?
I have tried using boot-repair, but I could not install it on live Ubuntu (as the Internet connection is not working), so it is working in my 'installed' version of Ubuntu. There I am not able to use the 'recommended repair' option.
Here is my pastebin link: http://paste.ubuntu.com/15306542/
Fresia
  1. Disable hibernation and fast startup in Windows.
    • Open command prompt as administrator and execute:
      powercfg /h off
    • Open Windows Control Panel.
    • Go to Power Settings.
    • Uncheck Fast startup.
  2. Shutdown the machine completely - do NOT reboot.
  3. Reinstall GRUB boot loader for Ubuntu in EFI mode.
    • Boot from the Ubuntu installation medium.
    • Select Try Ubuntu without installing.
    • Open a terminal and execute:
      sudo mount /dev/sda7 /mnt
      sudo mount /dev/sda2 /mnt/boot/efi
      for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
      sudo chroot /mnt
      grub-install /dev/sda
      update-grub
    Note:
    sda = disk | sda2 = EFI partition | sda7 = system partition
  4. Boot into BIOS and select Ubuntu as default system.
cl-netbox
  • 31,491
