Trying to install GTK as it was required by a another package.
So I ran apt-get install libgtk-3-dev
But getting unmet dependencies error.
Output
  Reading package lists... Done
Building dependency tree
 libgtk-3-dev : Depends: libgdk-pixbuf2.0-dev (>= 2.30.0) but it is not going to be installed
                Depends: libpango1.0-dev (>= 1.36.7) but it is not going to be installed
                Depends: libcairo2-dev (>= 1.14.0) but it is not going to be installed
I know that this error usually happents due to broken package. But apt-get install -f show no problem.
Output of apt-get install -f
Reading package lists... Done Building dependency tree
Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Also no output for apt-mark showhold Output for apt-cache of involde package sudo apt-cache policy libgtk-3-dev
 ibgtk-3-dev:
  Installed: (none)
  Candidate: 3.16.7-0ubuntu3
  Version table:
     3.16.7-0ubuntu3 0
        500 http://in.archive.ubuntu.com/ubuntu/ wily/main i386 Packages
apt-cache policy libgdk-pixbuf2.0-dev
 libgdk-pixbuf2.0-dev:
  Installed: (none)
  Candidate: 2.32.1-1
  Version table:
     2.32.1-1 0
apt-cache policy libpango1.0-dev
libpango1.0-dev:
  Installed: (none)
  Candidate: 1.36.8-3
  Version table:
     1.36.8-3 0
apt-cache policy libcairo2-dev
libcairo2-dev:
  Installed: (none)
  Candidate: 1.14.2-2ubuntu2
  Version table:
     1.14.2-2ubuntu2 0
sudo apt-get check and sudo dpkg -C has no output.
Output of sudo apt-get update
Hit http://ppa.launchpad.net wily InRelease
Hit http://ppa.launchpad.net wily/main i386 Packages
Hit http://in.archive.ubuntu.com wily InRelease
Hit http://ppa.launchpad.net wily/main Translation-en
Hit http://in.archive.ubuntu.com wily/main i386 Packages
Hit http://in.archive.ubuntu.com wily/universe i386 Packages
Hit http://in.archive.ubuntu.com wily/restricted i386 Packages
Hit http://in.archive.ubuntu.com wily/multiverse i386 Packages
Hit http://in.archive.ubuntu.com wily/main Translation-en
Hit http://in.archive.ubuntu.com wily/multiverse Translation-en
Hit http://in.archive.ubuntu.com wily/restricted Translation-en
Hit http://in.archive.ubuntu.com wily/universe Translation-en
Output for cat /etc/apt/sources.list
deb http://in.archive.ubuntu.com/ubuntu/ wily main universe restricted multiverse
EDIT: I think libpng12-0 is causing the problem tried to install libpng12-dev using apt-get but got this error
 libpng12-dev : Depends: libpng12-0 (= 1.2.51-0ubuntu3) but   1.2.51-0ubuntu3.15.10.2 is to be installed
Tried installing the latest version of libpng12-0 from source but still showing the same error.
EDIT2(Sollution?): Didn't do nothing much just installed libgtk-3-dev using aptitude and accepted the solution to downgrade libpng12-0 and it worked
This isn't a case of existing broken dependencies (which apt-get install -f would attempt to fix), it's that it can't get the packages it needs to install the new package.
This could happen for a few reasons:
  • You have an active repository that is suggesting a newer version of libgtk-3-dev (or its direct dependencies) which doesn't also include the right versions of the other dependencies.
    This can be a common issue for people who install tons of PPAs. Some versions get bumped so high that dependencies can't be worked out sufficiently.
  • You don't have the right dependencies enabled (maybe something's in universe?)
  • You haven't run an apt-get update recently?
  • It's a straight-up bug in libgtk-3-dev (or one of its dependencies). File a report on Launchpad.
If you're just compiling stuff, a "quick" workaround for problems like this is to spin up a clean LXC (or other) virtual machine. This will let you start afresh without using up too much disk space.
Oli
  • 299,380
