I use ubuntu 14.04 LTS. I used Ubuntu screenshot application in my computer. But it can maximum take a screenshot of whole screen.
What can I do if I want to take screenshot of a page which is larger than the screen i.e. webpage?
alhelal
  • 2,741
If you just need a photo of the site in its default state, you can do that from the command line using gnome-web-photo without even visiting the site in your browser.
Or if you already use the advanced screenshot tool shutter, the command will automatically be integrated there as well.
Installation:
You need the package gnome-web-photo installed. Get it with the command below:
sudo apt-get install gnome-web-photo
Help overview:
Here are the options that gnome-web-photo supports:
$ gnome-web-photo --help
Usage:
  gnome-web-photo [OPTION...]
Help Options:
  -h, --help                 Show help options
  --help-all                 Show all help options
  --help-gtk                 Show GTK+ Options
Application Options:
  -m, --mode                 Operation mode [photo|thumbnail|print]
  -c, --user-css=CSSFILE     User style sheet to use for the page (default: /usr/share/gnome-web-photo/style.css)
  -d, --delay=D              Delay in seconds to wait after page is loaded, or 0 to disable delay (default: 0)
  -t, --timeout=T            Timeout in seconds to wait to load the page, or 0 to disable timeout (default: 60)
  -f, --force                Force output when timeout expires, even if the page is not fully loaded
  -w, --width=W              Desired width of the web page (default: 1024)
  -s, --thumbnail-size=S     Thumbnail size (default: 256)
  -p, --printer=PRINTER      Print page on PRINTER (default: none, save as PDF)
  --print-background         Print background images and colours (default: false)
  --disable-plugins          Disable embedded plugins in the rendering engine (default: enable plugins)
  --file                     Argument is a file and not a URI
  --display=DISPLAY          X display to use
Usage examples:
To capture e.g. http://askubuntu.com as PNG image, you could type the following command:
gnome-web-photo "http://askubuntu.com" askubuntu.png
Here is the created PNG image: external link to image on imgur.com
If you want a PDF like the print preview you would get from your browser instead of a PNG, use gnome-web-print. It's a shortcut for gnome-web-photo --mode=print:
gnome-web-print "http://askubuntu.com" askubuntu.pdf
It also supports creation of a small thumbnail image in PNG format. gnome-web-thumbnail is again a shortcut for gnome-web-photo --mode=thumbnail:
Additional notes:
Don't forget the http:// or https:// protocol! Otherwise the command may crash and you'd have to abort it using Ctrl+C.
Note also that it also prints some normally irrelevant output, e.g. the Java version it uses... Just ignore that as long as there are no error messages...
Byte Commander
  • 110,243
I use Awesome Screenshot add on in Firefox. You can get similar extension in chrome also. It enables you to capture both selected part or the whole page.
Subin Shakya
  • 31
