I upgraded ubuntu to 15.10, then I tried to compile a gtk app and found out I had no GTK installed.
So I ran
sudo apt-get install libgtk-3-dev
but this is the output
Reading package lists... Done
Building dependency tree
 libgtk-3-dev : Depends: libegl1-mesa-dev but it is not going to be installed
How can I fix this? I have no idea why there are these "unmet dependencies"... something wrong on the ppa side?
Severus Tux
  • 10,126
Dean
  • 195
As you receive the you have held broken packages error message,
execute sudo apt-get install -f, which will fix it.
More information from the man page :
-f, --fix-broken
           Fix; attempt to correct a system with broken dependencies in place.
           This option, when used with install/remove, can omit any packages
           to permit APT to deduce a likely solution. If packages are
           specified, these have to completely correct the problem. The option
           is sometimes necessary when running APT for the first time; APT
           itself does not allow broken package dependencies to exist on a
           system. It is possible that a system's dependency structure can be
           so corrupt as to require manual intervention (which usually means
           using dpkg --remove to eliminate some of the offending packages).
           Use of this option together with -m may produce an error in some
           situations. Configuration Item: APT::Get::Fix-Broken.
Severus Tux
  • 10,126
