15
Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://dl.google.com/linux/chrome/deb stable InRelease' doesn't support architecture 'i386'
is what i get when performing
sudo apt-get update.
I found a solution on this website (Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'xxx' doesn't support architecture 'i386')
and performed
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
but got back
No command 'deb' found, did you mean:
 Command 'dex' from package 'dex' (universe)
 Command 'debc' from package 'devscripts' (main)
 Command 'deb3' from package 'quilt' (main)
 Command 'dab' from package 'bsdgames' (universe)
 Command 'derb' from package 'icu-devtools' (main)
 Command 'debi' from package 'devscripts' (main)
 Command 'xdeb' from package 'xdeb' (universe)
 Command 'dwb' from package 'dwb' (universe)
deb: command not found
I am unable to comment on the old post because i don't have 50 reputation so i apologize for a repeat question.
It's not a terminal command; it's about the contents of this file:
/etc/apt/sources.list.d/google-chrome.list
If you have a 64 bit installation, you should edit the file and change the last line to:
If you have a 32 bit installation, you'd better just delete the file. There won't be any further updates of Google Chrome for 32 bit.
This command will do!
sudo sed -i -e 's/deb http/deb [arch=amd64] http/' "/etc/apt/sources.list.d/google-chrome.list"
Or check on the files /etc/apt/sources.list.d/google-chrome.list and /etc/apt/sources.list, and change the line below:
deb http://dl.google.com/linux/chrome/deb/ stable main
Finally..
sudo apt-get update
Gayan Weerakutti
  • 3,830
  • 28
  • 39
-2
If you have Google Earth installed, please do the same. Remove deb http://dl.google.com/linux/chrome/deb/ stable main
Add deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
-3
There is a simpler solution than that one you found.
Go to "Software & Updates" => "Other Programs" and unmark dl.google.com/linux/chrome/deb/stable.
This will fix your problem This will disable the update of Google Chrome too, but is the better way while I other solution doesn't appear.
muru
  • 207,228
