How do I change the language of the terminal to English?
I am familiar with using vi.
If the terminal language is controlled by etc/default/locale, what am I supposed to change there?
LANG="el_GR.UTF-8"
LANGUAGE="el:en"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
kos
  • 41,268
OJeik
  • 89
Tl; dr
since you want to set everything to English (assuming that programs using GNU gettext should use Greek as a fallback language):
export LANG=en_US.UTF-8
export LANGUAGE=en:el
Or if some LC_* variables are defined already in your shell's environment and you wish to override them:
export LC_ALL=en_US.UTF-8
To make the settings stick, add the exports at the end of ~/.bashrc.
Changing /etc/default/locale will affect the whole system's locale and consequently the locale of all users who didn't set a specific locale, so you shouldn't change it if you want to change only the language of the command running in your user's terminal / console.
The locale of the commands running in your user's terminal / console can be changed by exporting the following environment variables:
LANG
LANGUAGE
LC_ADDRESS
LC_ALL
LC_COLLATE
LC_CTYPE
LC_IDENTIFICATION
LC_MEASUREMENT
LC_MESSAGES
LC_MONETARY
LC_NAME
LC_NUMERIC
LC_PAPER
LC_TELEPHONE
LC_TIME
LANG defines the value to be used for each non-explicitly defined LC_* variable; so if none of the LC_* variables is currently defined in your shell's environment (that is the default behavior, if env | grep '^LC_' doesn't output anything it means that's the case) and you wish to set the value of all the categories to en_US.UTF-8, simply export LANG:
Otherwise you'll have to either also override each previously defined LC_* variable or (alternatively, more easily) just export LC_ALL, which overrides any previously defined LC_* variable:
However programs using GNU gettext will rely on LANGUAGE rather than LANG / LC_ALL (unless LANG / LC_ALL is set to C) and will set the language based on its content. LANGUAGE should define a list of colon-separated languages. If a translation for the first colon-separated language listed is not available, the program will try to use to the second colon-separated language listed etc; for example, to set English as the preferred language and Greek as a fallback language:
So in your case, since you want to set everything to English (assuming that programs using GNU gettext should use Greek as a fallback language):
kos
  • 41,268
Question was: "How do I change the language of the terminal to English?".
Put
LANG=C
or
LANG=C.UTF-8
(the world has turned ... UTF8 became common) into
.bashrc
or
/etc/bash.bashrc
After reboot it works for terminals. Does not affect GUI.
If language setting shall apply to remote (SSH) login use
.profile
or
/etc/profile
That's all. Other locations may apply!
opinion_no9
  • 1,072
