Starting March 2016, Software Updater displays "Failed to download repository information," and "Check your internet connection when attempting to update." What's causing it and how can I fix it so I can update my computer?
I have Google Chrome installed and I'm running Ubuntu 14.04 64bit.
Cause
When you install Google Chrome, it adds its own repository to your system so that it can be updated via Software Updater. Around the beginning of March 2016, Google dropped their 32bit builds for Chrome. On 64bit Ubuntu, Software Updater expects to see both 32bit and 64bit versions of packages in a given repository. Since Google removed the 32bit version, Software Updater can't find that package anymore and produces an error that shows up as Failed to download repository information, Check your internet connection.
Fix the repo
In order to fix this, you have to tell the package manager that the Google repository is 64bit-only. To do this you have to edit the Google repository file to add [arch=amd64] after the deb at the beginning of the line. The following snippet will check if the error is indeed with the Google repository and make the change for you. Make sure you copy the whole snippet (it's one line) and paste it in your favorite terminal:
url=http://dl.google.com/linux/chrome/deb/; if sudo apt-get update 2>&1 >/dev/null | grep --quiet "$url"; then for file in $(sudo grep -Rl "deb $url" /etc/apt/); do sudo sed -i 's/^deb/deb [arch=amd64]/' "$file"; done; fi
Upgrade Chrome
Close and re-run Software Updater and upgrade Chrome to the latest version - 49.0.2623.87-1 or later.
I added [arch=amd64] to the /etc/apt/sources.list.d/google-chrome.list as suggested but was still getting the error.
I noticed there was a second possible reason for the error.
On my system there is a file called additiona-repositories.list in /etc/apt/sources.list.d. This file also needed the [arch=amd64] added in order to clear the error.
I added directly to the url using the update manager "mintUpdate 4.9.3.3" by clicking on edit>software sources, entering my password, selecting "additional repositories (on the left), highlighting the item that matched:
deb http://dl.google.com/linux/chrome/deb/ stable main
Clicking "Update URL" and adding [arch=amd64] just after the deb as such:
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
Though it's not as fancy as the terminal method it'll work for those of us that are GUI oriented.
muru
  • 207,228
Nich
I'm using 14.04 64 bit and also getting "Failed to download repository information". I used the code snippet. I then ran the software updater ... It ran perfectly and I updated to the latest google chrome.
I ran the software updater a second time. Now I get the error "Failed to download repository again". I examined the /etc/apt/google-chrome.list file and found the [arch=amd64] missing. However, the /etc/apt/google-chrome.list.save file did contain the [arch=amd64].
So I ran the code snippet again. The software updater now runs without error. And the /etc/apt/google-chrome.list file contains the [arch=amd64].
It appears to me that updating chrome will automatically generate a new /etc/apt/google-chrome.list file without the [arch=amd64] ... forcing you to re-run the code snippet again. So the snippet is a temporary fix until the file is again automatically generated.
Note: This is the contents of my /etc/apt/google-chrome.list:
### THIS FILE IS AUTOMATICALLY CONFIGURED ###
# You may comment out this entry, but any other modifications may be lost.
daniel
  • 13
Quick short term solution for Ubuntu (14.04)
  • start software updater
  • wait for the 'Failed to download repository information' error
  • select 'settings...'
  • select 'close'
now the updates are available :-)
muru
  • 207,228
Vic
  • 391
