I have a number of ICC color profile files for monitor calibration. They can be imported and work correctly on Ubuntu, but the titles they were created with are not helpful so I'd like to change them.
As far as I can tell there's no way to change the title from the Color Settings application.
I've found that with colormgr I can install a profile and change the title that appears in Color Settings like so:
colormgr import-profile <icc-filename> | grep "Profile ID"
colormgr get-devices | grep "Device ID"
colormgr device-add-profile <monitor-device-id> <profile-id>
colormgr profile-set-property <profile-id> Title "<new-title>"
However, verifying the checksums of the original ICC file and the imported copy in ~/.local/share/icc, I can see that nothing has changed in the imported file so the new title must stored somewhere locally in my system.
I'd like to be able to share these files with other machines so I'd like to change the title stored in the file itself.
Is there any way I can change the title stored in an ICC file using software in Ubuntu?
OK, finally I did it under ubuntu with IccXML:
open a terminal
install prerequisites:
sudo apt-get install build-essential
sudo apt-get install libxml2-dev
sudo apt-get install libtiff5-dev
make a working directory
cd $HOME
mkdir icc
cd icc
get the source codes:
wget http://netcologne.dl.sourceforge.net/project/sampleicc/sampleicc%20tar/SampleIcc-1.6.8/SampleICC-1.6.8.tar.gz
wget http://netcologne.dl.sourceforge.net/project/iccxml/IccXML-Src/IccXML-0.9.8/IccXML-0.9.8.tar.gz
extract and compile SampleICC
tar -xzf SampleICC-1.6.8.tar.gz
cd SampleICC-1.6.8/
./configure --prefix=$HOME/icc/
make -j
make install
extract and compile IccXML
tar -xzf ../IccXML-0.9.8.tar.gz
cd IccXML-0.9.8/
PKG_CONFIG_PATH=$HOME/icc/lib/pkgconfig ./configure --prefix=$HOME/icc
make -j
make install
Get a testfile and do the job:
cd $HOME/icc/bin
wget http://www.tftcentral.co.uk/icc_profiles/dell_2707wfp.icm
./iccToXml dell_2707wfp.icm dell_2707wfp.xml
gedit dell_2707wfp.xml
Now go to the end of the file, change the description data as you want, save the file and close gedit.
./iccFromXml dell_2707wfp.xml dell_2707wfp_new.icm
OK, have a look on the original:
./iccDumpProfile dell_2707wfp.icm ALL | grep -A 1 textDescriptionType
Output:
Type:   textDescriptionType
"Dell 2707WFP.icm"
and a look of the new one:
./iccDumpProfile dell_2707wfp_new.icm ALL | grep -A 1 textDescriptionType
Output:
"Dell Test 2707WFP.icm"
cmks
  • 1,914
An icc-file consists of tags. The tag of interest may be
tag xxx:
  sig      'desc'
  type     'desc'
  offset   2747620
  size     73
TextDescription:
  ASCII data, length 25 chars:
    0x0000: GRACoL2006_Coated1v2.icc
  No Unicode data
  No ScriptCode data
Ther are a lot of tools for creating and editing icc-files, commercial and open-source.
The ICC Profile Inspector incorporates the ability to modify many of the tag entries in a profile. It only runs on Windows or linux/wine.
Maybe for just editing the desc-tags it may be an acceptable solution to run a tool under linux/wine or under discrete windows.
If you want to run under discrete linux you should use IccXML. Just convert the icc-file to a xml-file, edit the desired tags an convert the xml-file back to an binary icc-file.
cmks
  • 1,914
