When I tried installing VLC plugin libde265 , I got this error message
E: Write error - write (28: No space left on device)
E: The package lists or status file could not be parsed or opened.
I also keep getting that /tmp is out of disk space. What should I do? Here's output of df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            2.9G   12K  2.9G   1% /dev
tmpfs           583M  1.5M  582M   1% /run
/dev/sda7        43G   29G   12G  72% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
none            5.0M     0  5.0M   0% /run/lock
none            2.9G   53M  2.8G   2% /run/shm
none            100M   44K  100M   1% /run/user
overflow        1.0M  1.0M     0 100% /tmp
/dev/sda5       385G  118G  267G  31% /media/shashank/F0007F2C007EF944
On using the command
sudo umount /tmp
I get
umount: /tmp: device is busy.
        (In some cases useful info about processes that use
         the device is found by lsof(8) or fuser(1))
Since earlier questions were just solved by running the above command,I am posting a new question about this find out any remedies if possible
Seth
  • 59,332
