i want to install visual studio in Ubuntu 14.04. Moreover, i want to write and compile c++ as well as run C++ by using visual studio. is it possible in Ubuntu 14.04.
I'd imagine not, Visual Studio uses a lot of the windows specific functions. You could try Wine but I am not sure how much luck you'd have with this. If you want to use C++ though there are plenty of IDE's you could use on Linux, I personally use Eclipse which has support for C++, might want to check it out.
- 11
The nearest way to do it, is to run a Windows virtual machine on the Ubuntu host using VirtualBox or VMware. I personally use Eclipse or Qt Creator to edit the code. On Linux machines, the compilation process is a bit trickier, and most people use the terminal console to do it. Here's a quick YouTube tutorial to help you get to know the ropes.
You should open the terminal, either by searching the apps or by pressing Ctrl + Alt + T.
Then type:
sudo apt-get update # This will update the list of programs you can download
sudo apt-get install build-essential
sudo apt-get install g++
There are plenty of such tutorials in the Internet.
- 111
