When enabling ModemManager, I don't see my serial-based SIM808 FONA in the list of available modems even though I'm able to get it working with pppd.
If I start ModemManager with service stop ModemManager && ModemManager --debug I see that it scans past serial devices when searching for modems but for every device I see:
modem-manager: (tty/ttyO4): port's parent platform driver is not whitelisted
Looking at the source code, I see that it checks the device for the udev flag ID_MM_PLATFORM_DRIVER_PROBE. If this flag does not exist, the serial port will not be scanned. It also checks for the ID_MM_CANDIDATE flag to see if it's a supported port further up, so I know it's at least able to read that.
So I added this flag as a new rule in a new file /etc/udev/rules.d/78-mm-uart4-enable.rules
ACTION=="add", KERNEL=="ttyO4", ENV{ID_MM_PLATFORM_DRIVER_PROBE}="1"
After reboot, I see this in udevadm info /dev/ttyO4
P: /devices/ocp.3/481a8000.serial/tty/ttyO4
N: ttyO4
E: DEVNAME=/dev/ttyO4
E: DEVPATH=/devices/ocp.3/481a8000.serial/tty/ttyO4
E: ID_MM_CANDIDATE=1
E: ID_MM_PLATFORM_DRIVER_PROBE=1
E: MAJOR=247
E: MINOR=4
E: SUBSYSTEM=tty
E: TAGS=:systemd:
E: USEC_INITIALIZED=30104
But I still get the same error from modem-manager even though I clearly have the flag set. How do I whitelist ttyO4 correctly?
