I searched the forums, but it seems anyone with a similar problem didn't get a proper solution. I have good wifi signal, other devices connect to the internet just fine, computer is connected to network, but I have no access to the internet on my browser or the software center.
Firefox and the Ubuntu Software Center won't connect to anything. I can't go online, download updates, or anything. When I start the browser it just sits there saying 'Connecting...' but does nothing. If I start the Software Center I get no options to install anything and I get no results if I search for anything.
I ran the script that I saw other people using (BTW, you guys don't make it very easy for a novice to figure this stuff out, we're not all code junkies!), but I'm not sure how to post the results in one of those imbedded windows. ~~If someone can tell me that, I will post the output of the script.~~ Added Link to results below.
Oh, and this netbook had Ubuntu 10.04 on it and it worked fine. Being obsolete and no longer supported, I foolishly thought it would be a good idea to install a newer version. I installed the 32-bit version since I only have 1 Gig of RAM.
Thank you.
Dmesg results, yet another wall of text!
2nd dmesg output for comparison
~~POSSIBLE SOLUTION: I disabled hardware encryption, set IPv6 to local only, and did a rfkill unblock all. That seems to have worked and network is humming now. I'm going to call this a fix guys.~~ EDIT works until it doesn't, then slow as hell, connection drops to 1 Mbs again, not sure why. Tried another fix, will report back how that works.
FINAL UPDATE: I replaced the Atheros Wifi card with a Broadcomm card. It worked immediately when I booted to a Live USB image. Unfortunately, it ceased to function after installation and boot from HD, but after a quick DL of FWwrapper and the installation of proper drivers, it worked like a charm.
TL;DR: Ditch the Ath9k card and get something else.
