I use Ubuntu 14.04 LTS, and when I take the screen shot, the default file name is given like Screenshot from 2016-02-29 11:08:10.png. I do not want the file name to have a space () and a colon (:). How can I change the file naming scheme?
norio
  • 171
Use the -f option as described in man gnome-screenshot:
-f, --file=FILENAME
              Save screenshot directly to this file.
So, try
On my system, the image is saved to my home folder. If you want it to be saved elsewhere, you need to specify the path like this, for example:
gnome-screenshot -f ~/Pictures/Screenshot_from_$(date "+%Y-%m-%d-%H%M%S").png
Read http://www.foragoodstrftime.com or man date for more on formatting dates.
DK Bose
  • 44,553
Setting the naming for file in gnome-screenshot is hardcoded into the source, specifically the screenshot-filename-builder.c part of the source code. If you specifically want to use gnome-screenshot, your best bet is to alter the source code.
There also are no external settings for that.
grep '<key.*\=' /usr/share/glib-2.0/schemas/org.gnome.gnome-screenshot.gschema.xml
    <key type="b" name="take-window-shot">
    <key type="i" name="delay">
    <key type="s" name="auto-save-directory">
    <key type="s" name="last-save-directory">
    <key type="b" name="include-border">
    <key type="b" name="include-pointer">
    <key type="b" name="include-icc-profile">
    <key type="s" name="border-effect">
    <key name="default-file-type" enum="org.gnome.gnome-screenshot.file-types">
You could always use the --file= flag in conjunction with date program. DK Bose actually posted this solution earlier, which baffles me why he deleted it. One could connect gnome-screenshot --file="$(date +%Y-%m-%d-%H%M%S).png" to a shortcut. That's the closest to what OP wants. And you could always seek alternatives,too, for instance shutter is a popular screenshot software on Linux, but I've never used it myself, so cannot endorse
