sudo apt-get -f install linux-firmware
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
amd64-microcode intel-microcode iucode-tool
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
linux-firmware
0 upgraded, 1 newly installed, 0 to remove and 1800 not upgraded.
36 not fully installed or removed.
Need to get 0 B/27.6 MB of archives.
After this operation, 50.7 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
linux-firmware
Install these packages without verification [y/N]? y
(Reading database ... 355777 files and directories currently installed.)
Unpacking linux-firmware (from .../linux-firmware_1.79.18_all.deb) ...
dpkg: error processing /var/cache/apt/archives/linux-firmware_1.79.18_all.deb (--unpack):
trying to overwrite '/lib/firmware/usbduxfast_firmware.bin', which is also in package firmware-linux-free 3.3
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
apt-get autoremove
You might want to run 'apt-get -f install' to correct these.
linux-image-generic : Depends: linux-firmware but it is not installed
E: Unmet dependencies. Try using -f.
Asked
Active
Viewed 8,353 times
Pilot6
- 92,041
You installed some custom linux-firmware-free package that conflicts with linux-firmware.
You can fix it by
sudo apt-get remove linux-firmware-free
sudo apt-get install linux-firmware
Pilot6
- 92,041
try using aptitude install linux-firmware - it will offer you some options of solving that dependency problem.
NOTE:
apt-get -f install is to be used without any package, as a separate command. You can tryapt-get -f install; apt-get -f install linux-firmware but not apt-get -f install linux-firmware. Of course use sudo accordingly.
tymik
- 154
