Can I run a command within another command for example:
twidge update date
date being the bash command date so effectively, twidge will update twitter with today's date. twidge is a CLI based twitter client.
twidge update date
You can try escaping the command like so
twidge update "$(date)"
Which will execute date and concatenate the output of the command into the twidge command.
According to the twidge help info
You can also omit the status, in which case a single line will be read from stdin and taken as your update. Example:
date | twidge update
Just pipe the command to twidge via stdin.
Yep, if I understand you properly, this will do it:
twidge update `date`
If twidge doesn't like it, try twidge update "$(date)", quotation marks to pass it in as one long string.
