Do you want to write your favorite Linux-iso to a USB-stick?
Are you confused by all the forum posts on the internet?
Below is the quick and mostly fail safe way to do it.
First use gparted to find if your usb stick is named sdb/sdc or something else. In a terminal
cd to the folder where the *.iso is located. In my case
cd Downloads
write the iso to the usb stick and make sure it was written with sync
sudo dd if=file.iso of=/dev/sdX bs=1MB && sync
where sdX refers to your USB drive.
In my case
sudo dd if=debian386.iso of=/dev/sdb bs=1MB && sync
It is done or it should be done, but in the Linux/GNU world it might not be. Check if it is done by rebooting or booting the computer where you want to run the installation or live-usb
if you do not know what dd or sync is then
man dd && man sync
Be careful with dd because it is powerful and will wipe your drive without asking for permission. It thinks you are God and like a slave executes your commands. It means you have to know your tools or they will bite you hard.
IMPORTANT: make sure you refer to the correct drive in your command otherwise it is possible that you lose your data.
